Labels on Caps Engine Bay
I'm doing an under the hood upgrade project. Part of the project includes painting the caps in the engine bay. I stopped by the dealer today and he told me that I could not buy the labels separate; I could only get them with the caps already installed.
Do you guys know where I can buy the labels??
Ron
Ron
Have not seen the labels sold separately - perhaps a sign shop can make you some, but not sure about the expense in doing that.
Use a scanner to see if you can copy (or take a picture). If that works you should be able to print using photo paper, or use thick regular paper and lamainate to make a label. I have done this for some similar applications, just not automotive.
Print first on plain paper until you get the size correct. I use photoshop to get the size correct.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Mr.Bill
