Clutch fluid change.
Old Apr 4, 2012 | 11:24 AM
walleyejack's Avatar
walleyejack
Default Clutch fluid change.
I am changing the clutch fluid in my C5,some say Prestone dot 4, some say don't use synthetic,Prestone is synthetic, anyone have a particular brand they like to use, did the search,lots of threads on how to change,but not much on brands.
Thanks al
Old Apr 4, 2012 | 11:31 AM
DarkBlueC5's Avatar
DarkBlueC5
I believe synthetic is fine - I think anything you get will be synthetic, and Dot 3 is fine unless you are planning on heavy braking, but you could do DOT 4 as well with no issues. What you want to avoid is Silicone-based fluid, which I think is DOT 5 or DOT 5.1 (one of the two...they get out of sequence at some point).
Old Apr 4, 2012 | 11:39 AM
PushinTheLimit's Avatar
PushinTheLimit
With mine... I just use what I have left over brake fluid. I use Ferodo Super Formula which is a DOT4 fluid with a dry boiling point of 626 F. Good stuff, but you can use pretty much any DOT3 or DOT4 fluid (Castrol, Motul, etc). Just like DarkBlueC5 said, no DOT5.
Old Apr 4, 2012 | 11:49 AM
walleyejack
Thank you,,,,Silicone is what I meant, not Synthetic, am getting old and senile. Looking at Prestone dot 4.
Thanks Al
Old Apr 4, 2012 | 12:02 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Look at the boiling points and get something with a high temp. I use Wilwood 600+, many use Motul 600 I think Castro has a high temp fluid as well
Old Apr 4, 2012 | 01:24 PM
betelgeuse's Avatar
betelgeuse
Just did mine today using the Ranger method. Super easy to do.
I used Prestone dot4 as recommended by Ranger.
Greg
Old Apr 4, 2012 | 02:49 PM
1999corvettels1's Avatar
1999corvettels1
I have done mine the ranger way, and it worked good, then it got to not shifting good again.
So now, I change it, drive the car for a week or 2, then change it again, it's working much better now.
I'm using Wal Mart Supertech brake fluid, DOT 3.
Must have missed the part or forgot where Ranger said what type to use.
Old Apr 4, 2012 | 02:55 PM
baxsom's Avatar
baxsom
if you mix 3 and 4 you wont get the full protection of 4 but it wont hurt anything.
Old Apr 4, 2012 | 03:53 PM
walleyejack
I have never changed mine, so that is why I think it is a good idea about now. Thanks for the input
Old Apr 4, 2012 | 04:07 PM
cds1's Avatar
cds1
How often should the clutch fluid be changed? Is there a more thorough way than Ranger/turkey baster? I know some vehicles have bleeder bolts near the slave cylinder for this type of work.
Old Apr 4, 2012 | 05:57 PM
betelgeuse's Avatar
betelgeuse
There is a bleeder. The problem is you have to take half the car apart to get to it.
Greg
To Clutch fluid change.
