M6 fluid change
Old Apr 4, 2012 | 03:56 PM
slvr bulit's Avatar
slvr bulit
Default M6 fluid change
I dont want to start a whats better post but have a question. I'm going to change the manual tranny fluid and the rear end oil. I'm going to use royal purple synchromax in the tranny ( its what I used last time) I forgot how many quarts I need. I think 4 is that right? Also what is the name of the royal Purple gear oil and how many quarts do I need for the rear end. Its for a 98 coupe. i tried the search but ended up reading a bunch of old post and got side tracked and never found what I was looking for.
Old Apr 4, 2012 | 04:39 PM
2KFRC5's Avatar
2KFRC5
http://www.gmpartshouse.com/downloads.php = Owner's Manual
1.5 Qts + 4oz Limited Slip Additive = R.E.
4.1 Qts = Trans
Old Apr 4, 2012 | 04:43 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The RP gear oil is called MAX-GEAR. It comes as either 75w-90 or 75w-140. The diff takes 1.7qts, the trans takes 4.1qts.
Old Apr 5, 2012 | 10:38 AM
slvr bulit's Avatar
slvr bulit
Thank you
To M6 fluid change
