So the past 2 weeks I've been doing some work on my car, and this was the first time I've had it up off the ground since I bought it last summer. This is what I found:
and after a few hours of cleaning:
I'm thinking it could be the driver side output shaft seal since it's so common, but I never suspected anything since I've never had a single drop of fluid leak onto my driveway. At least now that it's clean, if there is a leak, I will be able to see it
May be but looks like a trans pan gasket to me. May want to put it back up in the air and check the level. The car can get about almost 2 qts low befor it starts to slip.... Robert
I'd definitely prefer it to be just this compared to the output shaft seal (although the seal isn't terribly difficult to replace, it's just more involved).
Really man check the trans it may do some damage if it to hot on you even if it doesnt slip. That is a good amount of fluid over time as slow as it is leaking man..... Robert
Doesn't really look like the rear diff leak that is common - looks more like it could be transmission related or the seal between the tranny and the differential.
