Help removing fuel line.
Old Apr 5, 2012 | 05:41 PM
cadman96's Avatar
cadman96
Default Help removing fuel line.
I have a 2001 C5 and am in the process of replacing the MAP sensor. I just cannot get the fuel line off. I bought the special 3/8 plastic sleeve that slides up into the fitting, but no luck. It pushes in just fine but I must be doing something wrong.
Need help here.
Thanks.
Old Apr 5, 2012 | 05:54 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Try pushing in on the connection and then inserting the tool
Old Apr 7, 2012 | 05:04 PM
cadman96's Avatar
cadman96
Default Got it
I bought the tools at Advanced Auto Parts and the 3/8's tool required 3 wraps of masking tape to make it large enough to work. The fuel line came right off after that.
Old Apr 8, 2012 | 01:50 AM
yaknow's Avatar
yaknow
buy a decent tool, the cheap ones at the discount auto stores are junk, bought a good set at NAPA had no problems.
Old Apr 8, 2012 | 08:41 AM
johnson-rod's Avatar
johnson-rod
Squirt a shot of WD40 on the connection before using the tool.
To Help removing fuel line.
