DIC Gas mileage?
Old Apr 6, 2012 | 12:37 PM
bumr's Avatar
bumr
Default DIC Gas mileage?
This may have already been done before but let's get fresh numbers. Has anyone ever compared their actual gas mileage to the DIC indicator to judge it's accuracy? I'd like to hear what you found.
Old Apr 6, 2012 | 01:09 PM
bumr's Avatar
bumr
Originally Posted by 8VETTE7
mine is consistently within 0.1mpg of what I calculate based on gas pump gallons and odeometer miles. I reset mine every fill up so I'm not getting a cumulative mileage which might be considerably off especially if my right foot was unusually heavy the last tank fill up.
That sounds surprisingly accurate. Thanks for the reply.
FormerlyFiero's Avatar
FormerlyFiero
Oldtimer
Mine was about 2 MPG higher than actual when I first got it 9 months ago. It's within 0.1 of paper and pencil figures now, I hear it takes some time for it to get used to your driving style. Average town/country is 24 MPG for me, I'm seldom on a freeway. I don't baby it but i don't beat on it either, it's common for me to pull it out of OD in some twisties.
BTW, I reset the trip odometer at each fillup too.
Old Apr 6, 2012 | 02:11 PM
jrose7004's Avatar
jrose7004
The DIC on mine shows a couple of gallons better that it actually is.
Old Apr 6, 2012 | 02:32 PM
bumr's Avatar
bumr
Do you mean miles per gallon? Like showing 20 mpg when you're only getting 18?
Old Apr 6, 2012 | 03:32 PM
duramaxsky's Avatar
duramaxsky
Mine is real close. the one in my truck is off a little though. but the C5 is real close.
Old Apr 6, 2012 | 06:05 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
My 99 FRC is very close between the DIC and the actual mpg at fill ups.
My 99 6 speed hatchback the DIC shows about 2 or 3 mpg more than I actually get at fill ups. It might be because I have some mods and a tune on this car.
I also heard that there is a correction factor available if you have your car tuned, but I have not done that yet.
Just FYI, my C4's were very close (checked on two 94 6 speeds, and one 88 auto )
Old Apr 6, 2012 | 07:23 PM
rebelheart's Avatar
rebelheart
These things are surprisingly accurate.
Old Apr 6, 2012 | 08:22 PM
dacfan's Avatar
dacfan
Mine on the '99 adds about 1 mile (just to make me feel beeter because our love is mutual)
I can't remember if my old '91 even had a mpg display but I think it did.
I'm glad the '77 doesn't. I don't want to know what it says. It just hurts too bad to think about it.
Old Apr 6, 2012 | 08:45 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I have checked mine several times over the years. Always close enough that I don't bother checking anymore.
Old Apr 6, 2012 | 08:57 PM
c51stvette's Avatar
c51stvette
Mine is consistently 1-1.5 mpg higher than what I calculate manually.
Old Apr 6, 2012 | 09:01 PM
DBLTRGR's Avatar
DBLTRGR
Haven't checked my C5, but I've tested my Impala 3 times and it's exact.
Old Apr 6, 2012 | 09:22 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Mines off 10% to the plus side. If the dic reports 27 its really 25 point something.
Old Apr 6, 2012 | 09:25 PM
wilkinru's Avatar
wilkinru
Anyone know how they're doing the calculation? Obviously they get how fast you are going from the computer....but how much fuel you are using must be done by what the computer is telling the injectors to be using?
In this case, if your numbers are off, perhaps injectors aren't performing correctly? Just a thought.
Old Apr 6, 2012 | 09:48 PM
DBLTRGR's Avatar
DBLTRGR
Tire and wheel size is going to affect this.
Old Apr 6, 2012 | 10:32 PM
toddk's Avatar
toddk
MPG = miles / gallons. Only 2 numbers needed.
Fuel injector swaps often get flaky DIC MPG results if the tune data isn't right on, so I am going to guess the PCM calculates the amount of fuel used based on the duration the fuel injectors are commanded open. Or some derivative of that value.
Then total mileage is probably summed by capturing the momentary MPH at a set interval and calculating distance travelled between intervals (55mph = 80 feet/sec). Wheel size or diff changes would skew your speedometer mph which would also throw off total miles travelled as well as MPG. But those can also be adjusted by tuners.
Both Vettes I've owned with stock injectors & stock tune have been slightly optimistic by 1mpg or so. That tells me the injectors are flowing just a smidge more than the computer realizes.
Todd
Old Apr 6, 2012 | 11:47 PM
TorchRedRocket's Avatar
TorchRedRocket
Compared at almost every fillup, my DIC reads 3% optimistic (I.e. the DIC displays 20 mpg, and hand calculation would show 19.4 mpg.)
To DIC Gas mileage?
