Stain on the C5
Old Apr 6, 2012 | 09:00 PM
Green_Devil's Avatar
Green_Devil
Default Stain on the C5
I just saw that i have a dirt stain on the carpet, does someone know off any good stain removers i can use on my C5?
Old Apr 6, 2012 | 09:10 PM
momo20's Avatar
momo20
just about any of them will do...just want to brush it .then vacumm it out..
Old Apr 6, 2012 | 09:22 PM
Marine One's Avatar
Marine One
One product that I have had success with is an aerosol foam spray made by Simoniz called Tuff Stuff. You can find it at Wally or any automotive store. It removes just about everything and it's cheap (about 3 bucks a can).
Old Apr 6, 2012 | 09:25 PM
jrose7004's Avatar
jrose7004
I just use whatever carpet cleaner that the wife has around the house.
Old Apr 6, 2012 | 10:20 PM
dblerman's Avatar
dblerman
You must use GM stain remover that meets C5 specifications as per your owner's manual...
But I just use 409 carpet stain remover.
Old Apr 6, 2012 | 10:44 PM
DIABL0's Avatar
DIABL0
Never rub always blot. Rubbing will push the stain in to the fibers deeper.
Old Apr 6, 2012 | 11:39 PM
May have to try the Tuff Stuff. I have one small spot in my hatch area that I need to get out.
Old Apr 7, 2012 | 12:09 AM
leebay's Avatar
leebay
Works great.
Old Apr 7, 2012 | 08:49 AM
Darion's Avatar
Darion
use this, spray let it set a few minutes remove with a clean cloth, repeat if needed. Stuff works really well.
Darion
Old Apr 7, 2012 | 08:55 AM
b.lee's Avatar
b.lee
Bissell little green machine w/ heat!
These things work awesome in any car.
Old Apr 7, 2012 | 09:57 AM
TorchRedRocket's Avatar
TorchRedRocket
On my winter beater every year, I use laundry detergent with some warm water to get out the dirt and salt stains on my floor at and carpet.
Old Apr 7, 2012 | 10:11 AM
Baldfart's Avatar
Baldfart
I used a product called Folex. It works great. I bought it at a Ace hardware. But i believe Lowes or home depot has it.
Old Apr 7, 2012 | 10:16 AM
MGP1's Avatar
MGP1
2020 C6 of the Year Finalist - Modified
Any carpet stain remover spray works 4me..........
Old Apr 7, 2012 | 10:30 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
I've had good results with Woolite Heavy Traffic carpet cleaner. It comes in a spray can.
Old Apr 7, 2012 | 12:09 PM
Ron71's Avatar
Ron71
I too am a big fan of Tuff Stuff. I usually then follow with the Little Green Stem Machine with just water to pull out all of the cleaner.
Old Apr 7, 2012 | 01:36 PM
Sonny71's Avatar
Sonny71
Oldtimer
Tuff Stuff
Old Apr 7, 2012 | 08:04 PM
Marine One's Avatar
Marine One
My first experience with Tuff Stuff was probably about 25 years ago. I had purchased a used pickup and the PO had been a smoker. The smell was in everything and the white vinyl headliner and sun visors were stained yellow. I was amazed by the Tuff Stuff. I'd spray it on the vinyl and after a few seconds the white foam would change to a light brown color. I went through one can of Tuff Stuff and about 3 rolls of paper towels but when I was done the interior of that truck sparkled and no longer smelled like an ashtray.
I've found a few other uses for it. I keep a can in my boat for general interior cleanup. It does a great job on cleaning leather topsider shoes. It also does a good job of cleaning microfiber covered furniture.
Old Apr 8, 2012 | 09:42 AM
vettpapaw's Avatar
vettpapaw
RESOLVE-works better than anything I have used-does what it suppose to do
To Stain on the C5
