Another Lowering Question...
Old Apr 8, 2012 | 01:00 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Default Another Lowering Question...
I performed a search and read through the various threads, however I'm still getting conflicting infomation, so I want to pose the question again as the answer may have been buried somewhere...
What is the total difference (in inches) that you can lower the C5 Corvette on stock bolts? Assuming the car is at normal height, what is the maximum amount (in inches) that the car can be lowered?
Also, is there a measurement per rotation or thread count to work against?
Thanks!
Old Apr 8, 2012 | 01:07 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would guess that it would be about an inch all the way down on stock bolts.
Mr.Bill
Old Apr 8, 2012 | 03:06 PM
dougbfresh's Avatar
dougbfresh
Not enough to bother with.
Old Apr 8, 2012 | 03:50 PM
Caesar68's Avatar
Caesar68
I lowered mine last week. 1 inch max on the stock bolts sounds about right. 1/8 of an inch give or take is not a big deal.
Old Apr 8, 2012 | 04:45 PM
TorchRedRocket's Avatar
TorchRedRocket
Originally Posted by hotwheels57
Some claim they got 1".
I was able to achieve 5/8" front and 3/4" rear on uncut oem bushings and standard length oem bolts. That's with leaving the rear bolts at 2-3 remaining threads under the clip retainer and the front with a 1/8" gap between the bushing and spring.
That's also within the range that GM recommended. Any more than that and you're into the realm of form over function. It wasn't my choice.
I got about 3/4" all the way around with the front bolts turned all the way and 3 threads showing in the rear.
Old Apr 8, 2012 | 08:20 PM
PHIL MEMPHIS's Avatar
PHIL MEMPHIS
Mine was the same, 5/8 in on the front and 3/4 in on the rear. Doesnt sound like much, but made a big difference in the overall look.
Old Apr 8, 2012 | 08:48 PM
Vetterthanyou2's Avatar
Vetterthanyou2
Just got done with mine about 30mi s ago. Im saying 5/8 but hasnt been driven and settled all the way yet. Every little bit helps the look ALLOT!
Old Apr 8, 2012 | 08:51 PM
MSG C5's Avatar
MSG C5
I'm curious why you didn't lower the same amount on both the front and back?
I would like to try and narrow the gap a little between the tire and fender, however I had previously lowered all the way on stock bolts and I was scraping everywhere so I raised it up again. Now I'm wondering how much a difference would be to lower it 1/2" or 5/8" all the way around?
Old Apr 8, 2012 | 09:08 PM
PHIL MEMPHIS
That is the maximum on with the stock bolts. The rears adjusted more than the fronts.
It made the car level out. I like it this way.
Old Apr 8, 2012 | 09:17 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I'm sure you guys know this,,,,but get an alignment real soon after any suspension changes,,,tire wear is rapid and severe!
Old Apr 12, 2012 | 10:23 AM
RichAshley-Black99's Avatar
RichAshley-Black99
Especially in the front,ask me how I know!
Old Apr 19, 2012 | 12:38 PM
Lt. Dan M.'s Avatar
Lt. Dan M.
Is lowering really as easy as just turning the one bolt on each end of the cross spring?
Old Apr 19, 2012 | 01:14 PM
USA_Z's Avatar
USA_Z
I just lowered mine on the stock bolts a couple of weeks ago and got ~3/4" in the back and 1/2" in the front.
Old Apr 19, 2012 | 02:12 PM
Vetterthanyou2
Yes it is. In theory, at least. However it can be a real PITA getting to and TURNING them!
Old Apr 19, 2012 | 05:19 PM
TorchRedRocket
Make sure you soak them well in penetrating oil or WD-40 the day BEFORE you try turning them!
Old Apr 19, 2012 | 06:12 PM
Silverback51's Avatar
Silverback51
It took mine 2 to 3 weeks before it took a final set. I can see no reason for it, but that's how it worked out.
Old Apr 20, 2012 | 01:45 PM
6speedsteve's Avatar
6speedsteve
3/4" rear & 1/2-5/8 front is about right, the rear I think will lower more,
I made a wooden gauge to check my wheel well heights, and set them at 27" front & 28" rear, easier than a measuring tape.
Old Apr 21, 2012 | 05:42 PM
n8dogg's Avatar
n8dogg
Depends on the car, it's age, miles, options etc... Some are stiffer than others and will not give as much of a drop.
I had an 03 Coupe, base suspension, dropped a good full inch. It was noticeable, looked great.
My 04 Z06, hardly any drop at all, 1/4" max. Ended up swapping the bolts for lowering bolts.
To Another Lowering Question...
