Outdoor temp Display
Old Apr 9, 2012 | 12:37 PM
combatvet's Avatar
combatvet
Default Outdoor temp Display
My ac/outdoor temp display quit working on my 04Z. Has this happened to anyone else? need some help fixing the problem.
Old Apr 9, 2012 | 12:40 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Usually when the sensor goes bad it will constatly read something like 55* or 65* without changing.
What are your symptoms? No display at all ? or wrong temp? etc...
Old Apr 9, 2012 | 12:45 PM
corvettezman
If the display is working but dim, you will need this, or just send it off for repair. Easy DIY though if your a good with solder.
http://forums.corvetteforum.com/c5-t...splay-fix.html
Old Apr 9, 2012 | 01:48 PM
Mark Maple's Avatar
Mark Maple
This fixed the same problem for me a few weeks ago.
Old Apr 9, 2012 | 03:52 PM
roscoe118's Avatar
roscoe118
If your outside temperature is incorrect, you need to replace the sensor (about $10-$15) at your local Chevy parts store. Below shows where it is located:
If your HVAC display went out, then corvettezman (and Toque...) has got you covered.
Old Apr 9, 2012 | 11:14 PM
Great write up by Toque.
To Outdoor temp Display
