Headlight Issue
Old Apr 15, 2012 | 09:42 PM
Silverback51's Avatar
Silverback51
Default Headlight Issue
I have seen this before, and tried a couple searches and could not find it.
Drivers side opens fine. The passenger side only opens part way. It's not the gear as I replaced it last October when I first bought the car, nor is it making the grinding noise like the gear did.
This morning I figured I would pull it apart and see what was happening. Only problem is that I cannot get it open enough to tear apart. It's hitting a hard stop and neither the motor or the manual **** can get it to open any further.
I'm sure the answer is here somewhere, but I'm just not having any luck finding it.
Any help will be greatly appreciated.
Thanks in advance.
Old Apr 15, 2012 | 09:50 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Check and see if you can tell where it is binding at, There isn't too much that can bind in the linkage, Did you replace the gear with a metal one?
StingrayRebel's Avatar
StingrayRebel
has it been taken apart recently?... it's possible to install the lift arm in the wrong position which won't allow it to open/close properly due to it being in a bind... you should still be able to take it apart even if it won't open all the way... once you remove the 2 bolts that mount the headlight assy. to the frame you can tilt it into the bucket to give you access
Old Apr 15, 2012 | 10:02 PM
Silverback51
Yep, replaced it with a metal gear.
Old Apr 15, 2012 | 10:05 PM
Silverback51
It's been working fine since last October when I replaced the gear.
Since it will not open all the way, I cannot get the cover off since the bezel screw is still behind the fender, and you need the bezel off to get to the outboard cover screw.
Old Apr 15, 2012 | 10:06 PM
Mr.Bill's Avatar
Mr.Bill
Hmmm, If you don't see anything binding I guess it is possible for something in the gear threads to stop the motor... Just a guess.
Old Apr 15, 2012 | 10:49 PM
StingrayRebel
take a peek under it and see if you can see anything in the way... the only other thing i can think of is that the gear cover on the motor has separated which could cause the gear to try to work it's way out of the housing thus binding the gear with the worm drive... i have had problems with that happening, oddly enough on the passenger side only... the driver side sealed fine but i can't for the life of me get the passenger side to stay sealed for very long... i've used jb weld and a few different epoxies and nothing has held it for more than a week or so... i ended up buying the brace that rodney dickman sells so hopefully that will solve my problem
Old Apr 16, 2012 | 08:46 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Its also possible to get one of the three spacers in the wrong position and the case will still go back together. It will cause things to jam.
Old Apr 16, 2012 | 10:47 AM
Silverback51
Worked on it some more this morning and the gear case is broken. Need a new motor for that side.
To Headlight Issue
