You will most likely be buying them new. I doubt you will find used ones as once you epoxy them on, you need a jack hammer to remove them. I love the way they look on my vert..
Do you believe the epoxy method of installation is as strong as the thru bolt method?
Epoxy installation is the only way I would consider buying these, which I would like to do, but I need to be assured they would be strong.
Your "jack hammer" comment struck a note so I thought I would ask.
I used the supplied epoxy on mine, however I also used self tapping screws to secure them and they are rock solid. (Be careful because the gas tanks and carbon filter are located behind the back wall).
