Curious about the C5
Old Apr 16, 2012 | 05:00 PM
Jetranger's Avatar
Jetranger
1st Gear
Default Curious about the C5
I have never owned a Chevy, or any american car for that matter. I was interested in a C5, and began asking my friend about his. I've always liked the looks of them, but after the issues with C4's, I've been hesitant.
Anyway, after asking about my buddies, and driving it for a few hours, I noticed-
His headlights would pop up and stay on after the car was started (even in broad daylight)
The windshield wipers didn't 'seat' right after they were used. Instead, they would jump around on the bottom of the windwhield like they didn't know where they were suppose to be.
The windows rattled when rolled all the way down.
The oil pressure gauge was all the way at the top.
There were warning lights for 'Service column lock', 'Tire pressure' (on all 4 tires, it reported around 48psi, even though they were all around 35)
The radio is terrible (factory Bose).
It popped out of gear if you don't firmly push it in as the clutch is let out.
The power antenna doesn't work.
These are just the things I noticed in the short time I had it. My question is, are all C5's this problematic? This is in a dry climate, and he gets it regularly serviced. He says he has bypassed the column lock, and put about $1500 into the traction control computer.
I understand all vehicles have their issues, but I have NEVER driven one with this many issues with under 100k miles (88k).
After some research, I have found a lot of the things I listed as 'common'. Are there really this many common problems with the car?
Old Apr 16, 2012 | 05:14 PM
02z06dave's Avatar
02z06dave
I dont have any of those problems. I have had the car for almost two years and have only had an issue with the clutch master cylinder. I replaced it and have not had any problems since. Mine is a 2002 with 27k on it.
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I have been driving Corvettes since 1978 and between my wife and I we have had 12. I have never experienced any unusual or major problems with any of the C3 or C4 Corvettes. I also have not had any of the problems that you mention with any of my C5's except column lock on my 98 Convertible (battery was an Optima Red Top), bad wire in the column stalk on my '98 Vert and a headlight module on my wifes '00 Convertible went bad. Other than those 3 problems the have been exremely reliable. My current '99 has been flawless for the past 6 years and 2 months. TPM sensors have a life span of 7-10years and that is true for all cars with TPM's, the batteries have a limited life. The Bose system is fine for me. It sounds like your friend neglects and beats the crap out of his C5.
Old Apr 16, 2012 | 05:17 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Well list the problems with the C4 you mentioned. Until then you appear to be a troll. If your not good for you. Buy one and find out for yourself.
Old Apr 16, 2012 | 05:21 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have none of the issues listed, Sounds like your friend has a hunk.... Sure a 12 year old car will need some tending to as all cars, Your friend needs to get off his butt and fix his.
I did have the oil pressure issue, Installed a new sender and all is well.
Old Apr 16, 2012 | 05:24 PM
Zr-1Mike00's Avatar
Zr-1Mike00
Sounds like his car has a few issues.... It is all about how you maintain a vehicle. I have run into the steering column lock issue, however none of the other issues. My car is a '98 with just under 50K and runs like a dream! The factory BOSE in the car sounds great to me. Just don't max out the Treble and Bass all the way and it should sound sharp!
Old Apr 16, 2012 | 05:30 PM
sfc rick's Avatar
sfc rick
I have a 100k mile 98, and other than regular maintance issues it's a dream car! If you think buying a car 8-15 years old and they remain problem free, move on to the new car dealership and find something else. If you really like the C5 shop around for the one you like without problems.
Old Apr 16, 2012 | 05:41 PM
TwinTurboZ51's Avatar
TwinTurboZ51
I have a 1997 without any of thoise issues except the oil pressue sensor failed and that will peg the gauge. That was a 40 dollar part and 3 hours to fix myself.
Old Apr 16, 2012 | 06:09 PM
Dope's Avatar
Dope
Resident moron
Was it flooded or something? Lots of random electrical issues it sounds like. The windshield wipers and headlights especially. On my C5, the headlights don't even have an auto setting, it has to be turned on manually. Something isn't right there.
A lot of the other stuff sounds like wear items. Tranny synchros are probably going if you have to hold it in 1st for it to stay there. That can be an abuse item. The tire sensors are only good for so long, sounds like he wasn't gotten new ones. Newest model year C5 is almost 10 years old now, these things don't last forever.
But yes, the factory Bose is terrible. Even my Camaro that cost 1/3 less than the C5, has a way better stereo.
Fact is, it's a sports car that's quite cheap given the performance levels attained. Over the course of 10-15 years you have to keep up on maintenance or it's going to become a basket case. Try looking at 10-15 year old competitors like a Porsche and see how it's held up. Then look at the maintenance/repair costs for them too. Eye-opener for sure. In comparison, most of the things you mentioned are relatively cheap and easy fixes.
Dope
Old Apr 16, 2012 | 06:17 PM
needdlex's Avatar
needdlex
Same here, I'm at 100k on my 98 and the only thing I have wrong with mine is that the headlight motors were rebuilt by the last owner, and they don't always come up. I will fix it, just not right now.
I have also had the oil pressure sensor go out like Bill said earlier. It's a $50 or less part and time to swap them out.
If you like the C5, there is no substitute... Look around for a C5 that is in good shape, you should be able to find a cherry car for pretty cheap.
Old Apr 16, 2012 | 06:27 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Sounds like a poorly maintained vehicle to me.
Old Apr 16, 2012 | 08:29 PM
guido7834's Avatar
guido7834
Couldn't more.........
Old Apr 16, 2012 | 09:12 PM
theheartbeat's Avatar
theheartbeat
Sounds like ur buddy beats the **** out of his car... I mean I can have a 300k Lamborghini and if I don't care to keep things maintained than it will become a pos
Old Apr 16, 2012 | 09:15 PM
The only one off that list that I would say is somewhat common is the oil pressure sensor. The others, not so common. I've have 3 C5s and never had any of those problems.
Old Apr 16, 2012 | 09:24 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
it sounds like your friend neglects and beats the crap out of his C5.
the column lock is very common. other than that, it sounds like you had the experience of driving a very poorly cared for Corvette. the oil pressure sensor can be problematic, but I have an 04 center 6 speed convertible and haven't. experienced any of those problems. any abused vehicle will exhibit signs that make it appear that it suffers from common problems. if you asked the forum for reliability experiences, I'm sure you would have different opinion of the c5
Old Apr 16, 2012 | 09:30 PM
TraceZ's Avatar
TraceZ
That's a new one to me
I've never experienced it, but there is a fix for it on this forum
I've never experienced it, but it is a fairly common issue
The column lock problem I've experienced first hand. I had to replace a relay and install a bypass module. Total cost to fix : $75 As far as the tire pressure reading being off - That's a new one to me
I like the way my factory Bose sounds. I actually go sit in it on occasion, just to listen to music.
That's a new one to me but I've heard of it happening on other cars so I suppose it's possible for it to happen to a Vette.
That's a new one to me. I know for $15 you can buy a replacement power antenna mast online. As long as the motor is good, that should cover it.
Old Apr 16, 2012 | 10:56 PM
striper's Avatar
striper
All of the problems you've mentioned are easily fixed. It's unusual to have so many on all one vehicle. Sounds like your friend treats his car like a piece of crap and doesn't care about maintaining it. My '03 Z06 has a 100k miles on it and needs none of those repairs, and it still looks brand new!
To Curious about the C5
Old Apr 16, 2012 | 11:36 PM
Chilliwack vettes's Avatar
Chilliwack vettes
I've only had my '98 for a few months but have not had any of the problems you've encountered. Although I do plan on upgrading the Bose, it's tolerable right now and the gf thinks it sounds great! If you continue to poke around the forum, you'll find LOTS of owners who have nothing but positive to say about their C5's. They are a great running and long lasting car. With anything, normal regular maintenance will keep it running strong. Hope to see you posting pictures of your new C5 soon!
Old Apr 16, 2012 | 11:45 PM
Big Phil's Avatar
Big Phil
A C5 will give you less trouble.
Old Apr 16, 2012 | 11:54 PM
ALLEGRO's Avatar
ALLEGRO
I would NOT drive a car that did all that........hence I drive a 2003 Corvette !!
