C5 won't shift into reverse gear
Old Apr 17, 2012 | 07:59 AM
pjohnsto45's Avatar
pjohnsto45
4th Gear
Default C5 won't shift into reverse gear
bought my C5 Jul2003 (at age 43 for my retirement!). Still not retired yet. Car has been garage kept and has <30K miles. Drove from NJ to PA yesterday with no issues. Went to back the car out of the parking spot and could not get it into reverse gear. Actually seems like there is a "solid block" that forces me into 6th gear. Car runs fast/great in all forward gears. What is the issue with reverse? I already tried pushing/rocking the car in 1st gear based on a Google search. Any other ideas? Thanks in advance....parking in pull thru spots for now.
Old Apr 17, 2012 | 08:15 AM
Dennis 01's Avatar
Dennis 01
Had the same problem with mine, always shift
into reverse when parking it and before shutting
off the engine solved my problem
Old Apr 17, 2012 | 08:24 AM
pjohnsto45's Avatar
pjohnsto45
4th Gear
will do in the future, but for now how do I get it into reverse? the farthest over and down with the shifter is 6th gear.
Old Apr 17, 2012 | 09:14 AM
Dennis 01's Avatar
Dennis 01
The farthest over and UP is reverse
Old Apr 17, 2012 | 09:23 AM
3sACROWD's Avatar
3sACROWD
As stated by Dennis01, to the right and up is reverse. If that isn't the issue, your solenoid which prevents you from shifting into reverse while driving forward and aiming for 5th isn't working. The solenoid is about $60 if I remember correctly.
Old Apr 17, 2012 | 09:45 AM
pjohnsto45's Avatar
pjohnsto45
4th Gear
yes, sorry up and right...brain fart. Is the solenoid easily accessible? thx
Old Apr 17, 2012 | 11:36 AM
FourG63 97GST's Avatar
FourG63 97GST
I'll say so, you can get a straight shot at once you're under the car, might have to feel around a bit to find the bolts, since it near the 2oclock position on the trans
Old Apr 17, 2012 | 11:50 AM
pjohnsto45's Avatar
pjohnsto45
4th Gear
great, thanks. a little weekend work, sure beats cutting the grass.
Old Apr 17, 2012 | 01:30 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Do the shifter alignment. Its easy and fast...if you still have a problem after that, then its time to pull the tranny out.
To C5 won't shift into reverse gear
