[Z06] HalTech issue
Old Apr 20, 2012 | 03:55 AM
808EB03Z06's Avatar
808EB03Z06
Default HalTech issue
Has anyone had an issue with the killer bee II and a 102/102 setup? I tried putting mine on today and with the MAF on the setup it pushes the entire cold air assembly out too far. From the way it looks i'll have to trim about two inches off the ducting to make this work, otherwise i will be buying my third cold air setup in the last year, since none would have fit so far. thanks in advance
-Kerry
Old Apr 20, 2012 | 08:57 AM
striper's Avatar
striper
You should have bought a Callaway Honker in the first place, especially considering the money you wasted. One of the best in performance, OEM fit and quality, it looks good and works great. Only aftermarket with C.A.R.B. approval too, testifying to its quality.
Old Apr 20, 2012 | 02:53 PM
DARRYLZO6's Avatar
DARRYLZO6
-Kerry
I would try emailing the Haltech vendor here. Describe whats going on and he probably can help you out.
Old Apr 23, 2012 | 01:50 PM
Last C5's Avatar
Last C5
-Kerry
Are you using the stock MAF? My KB II is designed for the C6 probe type MAF and if fits just fine.
Old Apr 28, 2012 | 08:38 PM
808EB03Z06's Avatar
808EB03Z06
No it isn't the stock MAF. Being the idiot i am i went with the 102mm maf instead of sticking with the stock one. Got it to fit today wit a little massaging though
To HalTech issue
