Thermostat/temp???
Old Apr 23, 2012 | 03:42 PM
memmer's Avatar
memmer
Default Thermostat/temp???
I feel really stupid right now for having to ask this question.I just changed my thermostat from whatever was installed to what I thought was a 160 degree stat.My vette is now running 185 to 200 degrees and as high as 221 that is in 80 degree weather.The dic and the temp guage are pretty much in sinc.My feeling is if I install a 160 stat then I should be running around 160 degrees.I could not find on the stat what it actually is.I am thinking that I have been given a wrong stat.Any thoughts or info will be greatly appreciated
Fred
Old Apr 23, 2012 | 04:09 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
The temp determines when the T-Stat opens, not the temp you car will run...
Peace
Chip
__________________
..................Click for
Old Apr 23, 2012 | 04:12 PM
dougbfresh's Avatar
dougbfresh
Fred
Nope, as stated already, that's just when the T-stat OPENS, has very little to do with the warmed up temps of the coolant. Reprogramming the fans has more to do with it. Generally, all the 160 stat does is make it take longer for the car to get up to temp. The temps your seeing are NORMAL, no need to fool with them.
Old Apr 23, 2012 | 05:16 PM
Alludc's Avatar
Alludc
im in AZ and installed a 180 on saturday when it was 106deg out.
let it idle in the driveway 20 min, 196 was max. took it out for a 20mile drive, never broke 199 and never below 192. following morning was 73 outside and it sat around 189-191 putzin around town gettin coffee and such. railed on it on an off ramp on the way home through 4th gear and it made its happy lil way up to 201.
all that being said, I generally think 160s shouldnt be used in our cars. its too early/cold for it to open IMO. Also, if you were gettin 220s while driving around id look at the rest of your cooling system if you indeed put a stat in and its burped properly. if I didnt get that high in my extreme AZ Temps, theres no reason yours should.
Old Apr 23, 2012 | 05:22 PM
CCA Corvette Parts
But...
Run for the hills, hide your women and children
(incase you missed the previous several contentious threads on the topic)
I'm sure we'll be hearing why that is not the case
Peace
Chip
Old Apr 23, 2012 | 05:36 PM
DARRYLZO6's Avatar
DARRYLZO6
Fred
What they said. About normal. Also if part of the install was flushing the cooling system,make sure the air is purged from the cooling sytem,make sure there's no debris in the radiator cavity.
Old Apr 23, 2012 | 06:13 PM
memmer's Avatar
memmer
Thanks to everyone fore the information.I must be getting senile in my old age as I actually knew the mechanics of a stat.It must have momentarily left my brain.What is interesting is, I bought the 160 stat from A-Zone and I just found out that they do not carry or sell 160 degree stats.Thanks again.I feel better already
Fred
Old Apr 23, 2012 | 06:36 PM
RaW Z06's Avatar
RaW Z06
LMAO
Old Apr 23, 2012 | 07:15 PM
Jet-Jock's Avatar
Jet-Jock
Turn the AC on and it should run in the 196-198 range, stopped at a light most it will get is around 205-207, again AC on.
You can also either have a tune done to set the primary fan to come on at say 198, or get one of those switch systems to do the same.
Personally the way it comes from the factory seems to work fine.
Old Apr 23, 2012 | 07:23 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
with what all the others have said. I would suggest you look up under the car and ensure that you do no have an accumulation of dirt and debri on the radiator. You will be amazed at what will wind up there and block air flow, then add to rising temps.
Old Apr 23, 2012 | 08:38 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Fred
Sorry but I'm not going to make you feel better anymore. Auto zone sells a 160° stat. Duralast 15296 it was like $30. 99
http://www.autozone.com/autozone/par...923_1640_93208
I'm also going to buck the crowds opinion. The 160° stat runs 167° to about 174°. My fans are still programed for the 180° I had in there. It ran 192° the fans are set at 179° and 185° If fan temp was more of a factor why does my car run lower than the fan settings with the 160° stat?
All that said I think I would like a 170° stat thinking it will run in the low to mid 180's
Old Apr 23, 2012 | 08:53 PM
killain's Avatar
killain
Oldtimer
Default Temps. ?
Fred
Well I don't know too much about thermostats, Mine has a stock thermostat, I start it up and it runs in heavy traffic at 198-205, only once in awhile it'll go toward 215, but both the gauge and the DIC read about the same. It takes a really humid, 100 degree day to get the engine up to 220-225, but never over that. just my experience? Owners manual says it's fine at those temperatures. I never knew the fans cut off at speeds over 35 MPH. I change the coolant every 5 years. But my car is pretty stock, so . . .
Old Apr 23, 2012 | 08:56 PM
But really nothing wrong with the factory spec t-stat and the temps you are seeing are normal for a C5.
Old Apr 24, 2012 | 07:12 AM
dougbfresh's Avatar
dougbfresh
WHY??? My Challenger runs 220 all the time steady state, the vette is 200ish most of the time. Modern engines run HOTTER, they are DESIGNED THAT WAY. Don't "F" with it.
Old Apr 24, 2012 | 07:27 AM
runner140*'s Avatar
runner140*
Peace
Chip
You covered it with only one line.....great use of words.
To Thermostat/temp???
