c headlights
Old Apr 25, 2012 | 09:01 AM
beatty52's Avatar
beatty52
Default c headlights
need help. wanted to replace my oem hi beams with better (brighter) bulbs. when I check with some of the better bulbs they so they are not compatible. only bulbs that seem to be compatible are the silverstar and I along with others have not had much luck with these( burn out fast). any help would be greatly appreciated.
Old Apr 25, 2012 | 09:14 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
There are quite a few posts on the forum regarding improving the headlights on our C5's and a search will yield most of them. You can use the SilverStars, or go to a HID conversion kit, but while they may be brighter in the stock housing you will need to convert to a projector housing to take full advantage of them. At one time there was a number of claims made for converting to HIR bulbs but I have heard very little of late about them. Again seaching wil give you a ton of other information, opinions, and recommendations.
Old Apr 25, 2012 | 09:21 AM
beatty52's Avatar
beatty52
Default c5 headlights
thanks for the info. don"t want to do the hid coversion.
To c headlights
