Another column lock question
Old Apr 26, 2012 | 10:40 PM
rttmike's Avatar
rttmike
Default Another column lock question
I hate to keep kicking the dead horse here but I could not find the answer I was looking for.
I have been getting the "pull key for 10 sec" display for a week. So I do it and everything is good. Today I got the "service column lock" message. I drove home and all was ok. It got me wondering. So when the car was off and the key was pulled, I moved the wheel back and forth a few times. My column does not lock. I hear the motor engage and disengage when I turn the key but it stays unlocked. Do you think my locking pin has been removed/cut?
I also never got any of this until I had the bezel surrounding the stereo and the ignition switch removed about a week ago. Could I have bumped something to trigger this?
Do I need to worry about anything else besides my column locking? Or do I need to be concerned about the car not moving as well? 2000 FRC 6 speed.
Old Apr 27, 2012 | 07:50 AM
absolutscharf's Avatar
absolutscharf
If you hear the motor but the column doesn't lock, someone already did the recall (which includes removing the lock plate so the locking pin, even though its still moved by the lock motor, has nothing to lock against).
If your car is anything like mine (2000 M6 vert), despite the recall, you will eventually sit by the roadside with a "service column lock" message and a 2mph fuel cut-off. An LMC5 is very cheap insurance against that. Heck, I'd even pay double considering the frustration with the THREE times it happened to me AFTER the recall (the first two times, it went back to the dealership; the third time, I installed an LMC5).
Old Apr 27, 2012 | 07:56 AM
absolutscharf
And, yes, you may have moved something when you removed the bezel, but my guess is it's more a "moved something and changed the resistance through it just enough to upset the BCM" than a hard disconnect, so whatever you did may be both difficult to spot and difficult to undo. Which is why I like the LMC5 (which deals with the problem right at the BCM) over a CLB (which still leaves the wiring harness in the picture).
Old Apr 27, 2012 | 08:12 AM
spdislife's Avatar
spdislife
I had the same issue last fall when I put mine in storage. The battery died, I replaced it and now the issue is resolved.
Old Apr 29, 2012 | 06:58 PM
rttmike's Avatar
rttmike
I ended up ordering the LMC5. Hope to have it monday or tuesday. The person I talked to over there was VERY helpful.
Old Apr 29, 2012 | 07:46 PM
Good luck - hope the new part takes care of any column lock problems.
Old Apr 29, 2012 | 10:20 PM
leebay's Avatar
leebay
I was told by Compliance Parts that you can install a LMC5 even if you already have a CLB installed.
Old Apr 29, 2012 | 10:46 PM
Jesse Asis's Avatar
Jesse Asis
First there are 4 different RECALL fixes for this Column Lock Issue, First a "K" harness, Second "Re-programing", Third don't know but it could be the "Y" cable, and Fourth the "Solenoid Plate with NO hole". Mine had the third one I think some "Y" cable at the BCM. GM is responsible to just ONE fix attempt, the rest is on OUR penny.
I know cause I called GM for an anwer, my C5 is a paper weight right now pending a GM tech. tomorrow. I too have the LMC5 and LMC5 Un-Locking Kit, it didn't work (worked with Richard with Compliance Parts, he stayed by me but nothing we could do would unlock the solenoid). I can't wait to get this resolved.. I will update here when I do.
Call GM and give them your VIN number, if they fixed it with one of the above attempts, and it was done by GM they should have that information. If it is not listed, you may be able to have them put the fourth fix on, that really does fix it I hear.
Old May 3, 2012 | 09:51 PM
rttmike's Avatar
rttmike
LMC5 installed. Very easy install. No issues since. So far I am happy.
Old May 15, 2012 | 09:57 PM
Scoundrl's Avatar
Scoundrl
Over the last couple days I've had a few close calls with the CLB. I suspect it was voltage related on my car and each time I was able to get it to unlock after a few trys. I did order a LMC5 today though, I dont need to get stranded or look like a fool sitting there helpless over 38 bucks.
-Ken
To Another column lock question
