[Z06] Shifters!
Old Apr 28, 2012 | 12:53 AM
moravette's Avatar
moravette
Default Shifters!
I just bought a hurst short throw shifter for my 03 z06 but I have been seeing a lot of ppl say that have the c6 shifter in their c5 z06? Which shifter is the best way to go?
Old Apr 28, 2012 | 05:10 AM
RamAirTA's Avatar
RamAirTA
From: I'll Keep My Guns , Freedom And Money. You Keep The Change. FL
Very happy with the Hurst in my Z. Throws are nice and short and I really like the fact that it has adjustable stops for over-travel. Don't like sloppy shifters, Hurst is very solid.
Old Apr 28, 2012 | 08:43 AM
Oleman's Avatar
Oleman
I debated on shifters fror a while, bought a C6Z liked the shifter so well I put the same in my C5Z
Old Apr 28, 2012 | 09:57 AM
wSc*daywalker's Avatar
wSc*daywalker
I have the MGW.....totally happy with it
Old Apr 28, 2012 | 12:55 PM
SZEMTRS's Avatar
SZEMTRS
I'll second the MGW. I just bought my z and it had one in it and it's amazing. Super easy to shift and really smoothe. Love it!!!
Old Apr 28, 2012 | 12:59 PM
Gonzo's Avatar
Gonzo
Timely post
I would like to take my Hurst out of Z, but don't want to go back to stock. I'm getting older and I don't like fighting the hurst to shift.
Basically I love the short throw, but the Hurst is way to my effort. What do you reccomend for someone who does not like stock, to long and sloppy, or Hurst, to much effort????
Opinions wanted
Old Apr 28, 2012 | 01:00 PM
Quick 06's Avatar
Quick 06
Just installed an MGW mated with my RPS Twin Disk Clutch. All I can say is sweet... No rattle just precise shifts with very little throw.
Old Apr 28, 2012 | 01:10 PM
Gonzo's Avatar
Gonzo
How would you describe the effort need to shift it??? I find my hurst to be to much effort....
Old Apr 28, 2012 | 01:17 PM
SZEMTRS's Avatar
SZEMTRS
My MGW is like butter, very little effort and goes right into gear like it should.
Old Apr 28, 2012 | 01:52 PM
skyavonee's Avatar
skyavonee
Originally Posted by Gonzo
Timely post
Opinions wanted
You might not need to change your shifter at all. My MGW was too stiff for me when I first installed it, but after doing the transmission detent bolt spacer mod (aka the AntiVenom mod) it felt really good. I used a 1/8" spacer.
http://forums.corvetteforum.com/c5-g...venom-mod.html
http://forums.corvetteforum.com/c5-t...ffort-mod.html
http://forums.corvetteforum.com/c5-t...od-or-bad.html
This advice is applicable to the original poster as well. Since you already purchased the Hurst, I say install it and try it out for a while. If it's too stiff then try the above mod. If you still don't like it, then try the MGW shifter or the RSD Snap (which is a modified C6Z shifter).
Old Apr 28, 2012 | 01:56 PM
skyavonee's Avatar
skyavonee
What exactly does this mean, and how does it work?
Old Apr 28, 2012 | 02:46 PM
Gonzo's Avatar
Gonzo
Thanks guys........
Old Apr 28, 2012 | 03:26 PM
RamAirTA's Avatar
RamAirTA
Not sure if you're being a wise guy as I see I should have wrote "to prevent over-travel" but if your not, read on.
If you look at the following picture, you will notice an adjustment bolt and nut on the left and right side of the shifter. When adjusted properly, it prevents you from forcing the shifter further than it is supposed to travel in the gear that you are selecting. Thereby preventing internal damage to the transmission such as bending the shift fork, blocker rings etc.
http://corvettesofhouston.com/70-60-...st-shifter.jpg
To those who say their Hurst is hard to shift. Have you tried switching and/or adjusting the bias springs?
Old Apr 28, 2012 | 03:44 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
I have the c6 shifter cut down( think it is called RSD) I love it. I do have the MGW race ****..
Old Apr 28, 2012 | 05:22 PM
skyavonee's Avatar
skyavonee
Old Apr 28, 2012 | 05:40 PM
RamAirTA's Avatar
RamAirTA
Glad I could help.
Old Apr 30, 2012 | 12:17 PM
YYZ06's Avatar
YYZ06
I have the MGW and love it. I've done the anti-venom mod as well.
To Shifters!
Old Apr 30, 2012 | 12:20 PM
Dave_2003_TRZ06's Avatar
Dave_2003_TRZ06
I love my Hurst with the detent modification!
Old Apr 30, 2012 | 02:12 PM
pluslt's Avatar
pluslt
I have a Hurst and I love it. It is stiff which I imagine I could correct with some lighter springs. Other than that it goes right into gear perfectly and has a very notchy feel as opposed to the stockers which feel very sloppy or loose to me.
Good luck.
Old Apr 30, 2012 | 09:57 PM
2003corvettez06's Avatar
2003corvettez06
any of you guys owned or driven 99-04 mustang with the MGW shifter?
just wondering if anyone did how dose it compare to the C5 MGW shifter?
i had the MGW for 2 years on my mustang before i sold it and it was AMAZING ... I have purchased the RSD shifter its great shifter but dosent compare to the MGW that i had in the 2003 mustang gt
