coolant temps....
Yesterday I decided to take the car to work, on the way home I was in some stop-and-go with an outside temp of 96. The coolant temp got up to 232, which seems like it may be too high.
I've added a bit of fluid to get it to the correct level and changed the overflow tank pressure cap since buying the car, are there other things I should look at doing to help temps out? I worry what will happen when I go to my first track day.
Thanks,
Jason
Peace
Chip
Last edited by joestrazz; Apr 29, 2012 at 01:04 AM. Reason: forgot to put the name of the product
Why am I explaining this to you? You know more about these cars than I do. I assume you don't believe my temps? I'd be happy to jump on I95 and record a 10-15 minute video showing outside temp in the high 80's and my speed and op temps. I can do it cold or already at op temp to keep it honest.
Not trying to bust your chops, sorry if it came off that way.
The T-Stat is open when it opens. After it opens, it does nothing to
regulate the temp. when operating above its open position.
When it opens it allows flow from the block to the
radiator. As stated above, if you have a 160 or 180, at 185, both are fully
open. Only difference being that one opened earlier...
I can tell you that the waterwetter makes a big difference. Especially if
you are 50/50 or more water.
and
in all fairness, there are many tuners that believe that a lower
T-Stat helps, I just can't understand why...
Peace
Chip
Thanks,
Jason
http://www.saccitycorvette.com/COOLITv2.html
Cheers !!!
and
Peace
Chip
A couple other things. The way the stat works is holding coolant back. The stat opens and closes, as well as partially opens. If you completely removed the stat you overheat. It takes time for the heat transfer to occur. Move the coolant too fast it doesn't let the heat from the block and heads to transfer into the coolant to go to the radiator to transfer the heat to the atmosphere. Then the cooler coolant goes back to go absorb more heat. And so on..
The part I don't understand is why the car runs about 10° over the thermostat rating. I tend to think it would run closer to the rating. After running the stock 195°, a hypertech 180°, and now the Duralast 160° my experience shows about 10° over with all three. Next up is the 170° and I expect temps at 180°. Btw living in Florida the ac runs year round and I bet the fans do what the ac tells them to regardless of what I set them to. That might explain why I didn't see anything adverse by not reprogramming the fans when I changed to the lower stat.
The reason why the tuners want a lower temp stat is it allows them to advance timing and mixtures to more aggressive settings. That causes detonation. (Or predetonation) Pretty much your engine will start lighting the air/fuel mixture from compression and heat before the ignition system can fire. Like a diesel. You'll melt piston tops and other unnice things. So by running the car cooler you can get more aggressive with your tune.
I'm far from an expert but that's pretty much the way it's been explained to me.
