[Z06] LDCM Issue
Old Apr 28, 2012 | 02:56 PM
98C5for2's Avatar
98C5for2
Default LDCM Issue
I've been having a intermittant issue with the left door module of my '03 Z. I haven't been able to use any of the controls lately, but yesterday the car wouldn't start at work. It was ok in the morning. Checking the codes, LDCM shows no communication. Is it possible that there is an open circuit that would drain the battery? Before AAA jumped started the car, he checked out the alt and it was ok, however, this morning I got a message that said low voltage. Is this also one of the symptoms of a failing LDCM?
Thanks in advance.
Old Apr 28, 2012 | 05:30 PM
skyavonee's Avatar
skyavonee
Thanks in advance.
My guess is that the low voltage is causing your LDCM issue, not the other way around. If your alternator is indeed fine, then I would investigate the state of the battery and the chassis ground connections.
Old Apr 28, 2012 | 05:35 PM
98C5for2's Avatar
98C5for2
OK, I'll try that. Thanks.
To LDCM Issue
