plastidip question
Old Apr 28, 2012 | 04:23 PM
Jtirwin27's Avatar
Jtirwin27
Default plastidip question
Im going to do the lower rear bumper treatment tom. Do i need to prep it with anything other than the obvious wash and stripping of wax?
Old Apr 28, 2012 | 04:27 PM
memmer's Avatar
memmer
I would say to just follow the insrtuctions on the plasti dip can.
Old Apr 28, 2012 | 04:35 PM
Jtirwin27's Avatar
Jtirwin27
Well played. Sarcastic and helpful. I can appreciate both.
Old Apr 28, 2012 | 05:07 PM
momo20's Avatar
momo20
hey ! when i did mine ..i used some grease and wax remover..then some 2'' blue painters tape...took some news paper to control over spray..i also put some news paper behind the bumper cut outs ..pretty much any where i did not want the dip to go...then i worked from the bottom up to my tape line. don't spray to heavy as it will run and you will have to start all over again
Old Apr 28, 2012 | 05:13 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
How hard is it to cover the area above the exhaust tips? Or do you drop the exhaust?
Old Apr 28, 2012 | 05:19 PM
Jtirwin27's Avatar
Jtirwin27
Im just going to cover my tips with either paper or an old towel. Taoe off entire rear except what i want sprayed. Being over cautious is always a safe bet.
Old Apr 28, 2012 | 05:31 PM
momo20's Avatar
momo20
i just used newspaper...wrapped it around the tips,, then put a peice of tape on the bottom side..then took what was hanging out in the front..and taped it down...so i made a paper sleeve for the exhaust..so it would slip on and off..
Old Apr 28, 2012 | 05:50 PM
memmer's Avatar
memmer
I apologize! No sarcasm was intended just a quick response.
FRED
Old Apr 28, 2012 | 05:52 PM
Jtirwin27's Avatar
Jtirwin27
FRED
No offense taken. Im sarcastic and appreciate sarcasm when its needed. It was needed then, i didnt even consider turning the can over hahaha
Old Apr 28, 2012 | 06:15 PM
Drumbum675's Avatar
Drumbum675
Just wash it and wipe it with some Simple Green or any degreaser. The most important part is the tape line. You need to make sure that you are able to pull the tape line while the dip is still wet. It dries FAST. Make sure there is NO wind. The stuff will blow all over the place. Overspray on the tips or other part is no big deal. After it dries just peel or wipe areas where you got overspray. Pretty much impossible to screw anything up with this stuff.
It also good for pranks....I "spray painted" all over my brother's hood....lolololol He flipped out.....then I peeled it off in 2 seconds....
Qwik01's Avatar
Qwik01
I wipe the area with alcohol. One place I used plasti dip and didnt use alcohol there was bubbles that started to appear after a week.
Old Apr 28, 2012 | 07:58 PM
darkstar.c5's Avatar
darkstar.c5
Default dip your car
this guy has lots of useful youtube videos..
i know he's not doing a vette, but you can take some of the principles he's using to what you want to do.
Old Apr 29, 2012 | 11:57 PM
Tastee Twirl's Avatar
Tastee Twirl
LIFE IS SHORT HAVE FUN
St. Jude Donor '12-'13-'14-'15-'16-'17-'18
Just play n around
To plastidip question
