C5 - Touch Up Paint
Old Apr 28, 2012 | 10:00 PM
GreaseMonkey's Avatar
GreaseMonkey
PA Events Coordinator
Default C5 - Touch Up Paint
I haven't checked yet, but do dealers still carry touch up paint for earlier C5s? I need to find some 2001 Magnetic Red for my '64.
Old Apr 28, 2012 | 11:31 PM
Txsailor's Avatar
Txsailor
I found it in the little bottle with the brush& pen it says 1#12371339 code 86 WA379E on the outside and under a little flap there is another #...LE12371339NG
I wanted some erethane enamel to paint my calipers with. The kid at the parts store said that since magnetic red was a multi stage process it wasn't available in enamel. He came up with some that is a very close match. On the can it is marked 5AC Red Met Mica. I am pretty sure it was a gm color. It matches at least as well as the gm stuff but requires a harderner and reducer.
Old Apr 28, 2012 | 11:41 PM
GreaseMonkey
Where did you find it at?
Old Apr 28, 2012 | 11:48 PM
TAFMAN618's Avatar
TAFMAN618
Local paint shop may be able to match paint. Your color is a tri-coat. I attended the Funfest at Mid America last year and bought their exterior touch up paint. I have 2000 mag red and got the base and clear coat (two separate bottles).
Work perfectly for my small paint chips. Built up the base coat and let it dry thouroughly. Then, hit the top coat. Worked for me.
Old Apr 28, 2012 | 11:50 PM
Txsailor's Avatar
Txsailor
My local dealer got me the touch up paint. The enamel came from our local Parts Plus store.
Old Apr 29, 2012 | 07:24 AM
GreaseMonkey
Thanks to both of you
Old Apr 29, 2012 | 08:21 AM
The dealer should be able to get the paint for you in small bottles. If not, here are some good sources for touch up paint:
www.corvettepaintcodes.com
www.expresspaint.com
www.paintscratch.com
www.automotivetouchup.com
Old Apr 29, 2012 | 12:08 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Car quest will mix it for you, put it in saray can or bottle. Take your vin in or paint code and they can fix you up. That is if you have access to car quest
To C5 - Touch Up Paint
