[Z06] Dumb Question ???
Old May 13, 2012 | 02:55 PM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by ZEE-OH-6
will do, so far none have ever showed a "C" ALL "H" ?
The only way you will see them with a "C" is to check for codes while the engine is running. Once the engine is shut-off, they become "H" (History) codes.
Just completed a 80 mile frwy. cruise at 70 mph - after approx. 40 miles the CEL came on so I ran the diagnostic while driving - " keep your eyes on the road and your hands upon the wheel " During the Automatic mode I noticed a CURRENT code in the 10-PCM category but did not see it that well to remember it ? So when it went into Manual mode I scrolled through and it was gone - WTF ! but the Old HISTORY codes were back again:
10 PCM - P0171 H
10 PCM - P0174 H
So after I cleared them ( while still driving ) the CEL went out
Your thought ?
It could be the Current code you saw was one of the now History codes you listed above. If a current code clears itself while driving, it will then become a History code.
Old May 14, 2012 | 01:34 AM
ZEE-OH-6's Avatar
ZEE-OH-6
AHSO !
I wonder what's causing these codes ? Other than LEAN, I don't even know what these codes are ?
Old May 14, 2012 | 02:56 AM
ZeeOSix's Avatar
ZeeOSix
P0171 Fuel Trim System Lean Bank 1
P0174 Fuel Trim System Lean Bank 2
Bank 1 = driver's side cylinders
Bank 2 = passenger's side cylinders
Look for air leaks after the MAF sensor ... like where the intake connects to the throttle body.
And make sure the MAF sensor is clean and working correctly. Trash the K&N and get a good paper filter.
Old May 14, 2012 | 08:55 AM
02z06dave's Avatar
02z06dave
I had a similar situation happen to me about a year ago. My CEL came on, when i checked the codes, i had P0171 H and P0174 H. I cleared them and drove for a while and it was fine then the CEL would come back on and same 2 codes. I cleared them then a while later they would come back. The engine sounded fine and i checked all the clamps for the CAI and it all seemed ok so i went round and round clearing the codes then they would come back after 100 miles or so. A month or so later, i installed an oil catch can it was at that time that i found there was a little crack in the PCV hose. Since removing that cracked hose and installing the catch can i have not had any codes. So i think the hose was allowing just enough of an air leak to cause the problem. This may not be your problem but something to look into. You may also want to make sure all of your clamps are tight on your CAI. Good luck.
Old May 14, 2012 | 10:32 AM
ZEE-OH-6's Avatar
ZEE-OH-6
Thanks GUYS for taking your time to provide me information and lead me in the right direction
Do you think that I can continue to drive her as I try to find the problem or can this LEAN condition damage something ?
Old May 14, 2012 | 07:09 PM
ZEE-OH-6's Avatar
ZEE-OH-6
ttt
Old May 14, 2012 | 07:26 PM
Tech's Avatar
Tech
Two posts above yours gave you the information you're looking for. The only part I disagree with is ditching the K&N.
Your car has sensors to adjust the amount of fuel it needs to use at any given time. It has the ability to correct for pretty significant changes in airflow. In other words, cleaning a filter won't cause the lean condition.
The lean condition is most likely related to the intake tubing between your throttle body and the airbox. I suggest inspecting that very closely, and even if you can't see something obvious, loosening the clamps and making sure the according tube is seated fully on the throttle body and mass air flow sensor. If all of that checks out, you have a vacuum leak and should have someone familiar with LS1s take a look at it for you.
Old May 14, 2012 | 08:45 PM
ZEE-OH-6's Avatar
ZEE-OH-6
[/QUOTE]Your car has sensors to adjust the amount of fuel it needs to use at any given time. It has the ability to correct for pretty significant changes in airflow. In other words, cleaning a filter won't cause the lean condition.
The lean condition is most likely related to the intake tubing between your throttle body and the airbox. I suggest inspecting that very closely, and even if you can't see something obvious, loosening the clamps and making sure the according tube is seated fully on the throttle body and mass air flow sensor. If all of that checks out, you have a vacuum leak and should have someone familiar with LS1s take a look at it for you.[/QUOTE]
Thanks for the advice, I checked and tightened everything already but I will check and tighten again
But my original question still stands = Do you think that I can continue to drive her as I try to find the problem or can this LEAN condition damage something ?
Old May 15, 2012 | 09:21 AM
magneto10's Avatar
magneto10
My gas gauge froze up about 6 months after I bought it for about 1 hour but cleared up on its own - never happened again since ?
There was some PCM upgrade that the dealers do to correct it- If I remember it was around 2005 or so. This cleared the issue with some- but it still happens sometime with others.
In terms of driving with lean codes- from what I have heard- occasional lean codes with an aftermarket filter won't be harmful.
There is also an airflow issue turbulence type issue that can cause the code- Halltech makes a honeycomb metal (?aluminum) screen that is put in before the MAF.
Mine threw a few lean codes during an inspection a year ago- so I ended up buying it and I have not have a lean code since.
Might want to try that if you keep getting codes
Old May 15, 2012 | 11:24 AM
ZEE-OH-6's Avatar
ZEE-OH-6
Thanks - some more history, I had ALL the fluids changed by a Corvette shop here where I live and asked them to also clean my K&N intake filter. Prior to this maintenance work the CEL never came and she ran GREAT, but a few months after this work it started to miss and run crappy but the CEL never came on. I knew that the filter could be over oiled so I took the intake apart to clean the MAF, the clamps were pretty loose ( it should have been leaking air with the CEL coming on then ? ), took everything apart, cleaned the MAF and put it back together ( very tight ) and she ran GREAT again but a week later the CEL came on for the first time, that's when I added the Techtron ?
I have read about this screen that could help, but it did not have one originally ?
Baffled
I will check and tighten it again ?
Old May 16, 2012 | 01:03 PM
magneto10's Avatar
magneto10
The c5 Z06 did not have a screen before the MAF. If the MAF is clean and the connections are tight- I would suggest looking at/trying the honeycomb air screen.
http://www.halltechsystems.com/Hallt...r-p/hc.125.htm
I had my stinger air filter on for several years before I saw the lean codes at all- then last year I got three in two weeks (two were during inspections)- the Dealer wanted to do a 500$ evaluation. I tried the honeycomb- passed inspection and I have yet to see the lean code again
Old May 16, 2012 | 01:35 PM
ZeeOSix's Avatar
ZeeOSix
The 2001 Z06 did have a MAF screen, but the 2002+ models did not.
Old May 17, 2012 | 12:38 AM
  #33
ZEE-OH-6's Avatar
ZEE-OH-6
Guys thanks for the added info., since it's not my DD I don't move too quick with maintenance work - that darn thing call WORK gets in the way ! As soon as I get a chance I will clean / tighten everything again and see what happens then ? If this does not work I will go with the screen
Old May 20, 2012 | 10:00 AM
  #34
ZEE-OH-6's Avatar
ZEE-OH-6
Baffled
UPDATE - I have not had a chance yet to re-clean / re-tighten but I have been driving it alot and the CEL has not come back on yet, I wonder if it is just breathing better and the computer just needed time to be re-trained ?
