ACA kit, the hid does not align correctly
Old May 8, 2012 | 01:55 PM
hotrod03's Avatar
hotrod03
Default ACA kit, the hid does not align correctly
Intsalled the high beam hid in the aca and appears one the pass. side the high beam is pointing way left. the low beam is fine. I checked to make sure the lamp is in correctly? help
Old May 8, 2012 | 02:50 PM
SoDiezl350's Avatar
SoDiezl350
Please see this thread
http://forums.corvetteforum.com/c5-g...flyer-gp1.html
Old May 8, 2012 | 03:42 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I have ACA's too.
Its a known fact that the high beams on the ACA's are horrible because you can't aim them. The high beams and the low beams are part of the same assembly and you can't aim them separately.
Your going to notice that your high beams are pointed towards the ground right in front of the car. I had HID's in my high beam ACA's also. It was a waste of money honestly.
I did a similar mod as posted above, and its a wonderful setup now ! I got my high beams back ! I can see birds in the top of tree tops now.
With that said it does seem strange that one of your high beams are pointing way off in one direction.
1.) Are both your low beams aimed correctly ? Given that its all part of the same assembly if your low beams are correct, your high beams should at least be pointing forward.
2.) Look in the front of the ACA housing. Can you tell if the high beam bulb in question is pointed straight, or pointed off to one side ? You can see in the front of the reflector easily.
3.) Swap high beam bulb from side to side. See if the problem moves with the bulbs, or stays with the specific housing.
4.) Inspect both high beam bulbs and compare them to one another. Make sure they are the same bulb type, and have the same mating surface. If a bulb is not in the housing straight you will have issues like your seeing.
Toque
Old May 8, 2012 | 04:34 PM
hotrod03's Avatar
hotrod03
Originally Posted by Toque
I have ACA's too.
Toque
Oh Toque thank u so much! I'm on it an I will let u know!!
Gary
Old May 8, 2012 | 05:36 PM
Toque's Avatar
Toque
Gary
Also.... the high beam metal clips on the ACA high beam housing where the bulb is held are a little flimsy. I have more than once put in a bulb and it not be straight because one of the bulb tabs are not in the slot it should be. You should be able to notice the bulb is NOT straight by looking in the front of the housing though.
Toque
Old May 8, 2012 | 07:16 PM
hotrod03's Avatar
hotrod03
Originally Posted by SoDiezl350
so tell me if i have it right. adjust the low beam to where the high beam is a then make the adjust back as needed.. Is that correct? thanks Gary
Old May 8, 2012 | 07:39 PM
hotrod03's Avatar
hotrod03
yes i understand but how do i do the modification. See thread below im not sure if i have the procedure right.. Im thinking maybe its more involved than that, other than just phyiscally repositioning how the lamp sits in the housing. Im not sure but i bet you know thanks Gary
Old May 8, 2012 | 09:23 PM
hotrod03's Avatar
hotrod03
Bummmmmmp
Old May 8, 2012 | 09:31 PM
Toque's Avatar
Toque
PM sent
Old May 10, 2012 | 11:11 PM
hotrod03's Avatar
hotrod03
PM sent
Just sent my ACA to radioflyer to get them modified! Bi exion 55watt
Old May 11, 2012 | 10:12 AM
Toque's Avatar
Toque
That's the best way to do it ! I modified my own but its basically the same thing as what Radioflyer does...
I love the new Bi-xenon setup ! High beams are just wicked cool !
I can scare birds off the top's of tree tops now...
Toque
To ACA kit, the hid does not align correctly
