So i bought some new GM springs to install in my new to me 03 Z06. I pulled the valve cover a few minutes ago and the springs are not yellow. Are all of the bad springs yellow, or does the color not matter. The Current springs are unpainted. I dont see any markings on them.
I thought all ls6 factory spring were yellow but i could be wrong. I would say if they are not yellow they have been changed by a early owner. We i changed my 02 Z06 springs they were yellow
I looked down the oil filler of my '03 Z06 and see that mine does not have yellow springs either. My car is 100% stock so I'm thinking the later '03s and '04s do not have yellow springs. From what I read the yellow springs are the ones that seem to be failing. My car was manufactured in November of '02. What is the manufacture date of your car?
No worries. I replaced the valve springs on my 02 Z06 last rear at about 32K miles as pm. My oem springs were also unpainted as originally installed but GM.
btw the new GM springs are blue ( I have an uninstalled set ). Believe anyone getting the yellows are older inventory.
You can use many different brand aftermarket beehive springs with the stock retainers. Based on what people have said in this thread, it's hard to know if those are OEM or not. Too bad you can't find the previous owner and find out the history of the car.
