I didn't see answer to these two questions: does the hi flow cats and stock exhaust light up the "check engine" and what is weight gain with hi flow cars?
Astounding lack of information on the net about actual catalytic converter flow. Intuitively, the greater the flow, the lower the catalytic action taking place, and the greater the odds of a check engine light. Included with that will be weight. Less cells equaling less material and therefore less weight. I see Magnflow has CA legal universals they list as 5 lbs -- so two would be 10 lbs less the equivalent straight pipe or OEM cat they replace - could be a net loss in weight. Unless you want flanges or even better electric cutouts. I bet there's a youtube of how that would sound...
There's a lot of development that goes into catalytic converters. It's not nearly as simple as higher flow equals less conversion because there are more ***** to turn than just cell density. The cells can be made of different materials, metal or ceramic, and each can be made with different wall thicknesses. The catalyst compound can also be optimized for a given application, so you can actually reduce the flow restriction and maintain conversion performance.
Last I knew, it's NOT legal in CA to replace with high flow convertors, I may be mistaken, but supposed to replace *only* if defective/damaged, with stock replacements.
Hopefully this has changed, as modern high flow convertors are actually *better* at clean emissions, and flow more cfm to boot.
It should deepen and louden the sound some, not as significant, as running no convertors.
The only cats that are 100% legal in CA are OEM cats or CARB approved aftermarket cats. If you're looking into ANY aftermarket cats, make sure they have a CARB approval for your specific model and model year.
For anything other than those two choices: you can get away with anything until you get caught
Seriously though the Magnaflow CARB certified convertors are interesting, I'm sure it's one of the latest best technologies on how it works, giving minimal loss of performance with those convertors, but it remains to be seen!
High flow cats vs factory C5 cats: 1 hp difference at most. If you had cats from a 70's era car they were very restrictive, with the C5 cats to today there is virtually Zero difference vs aftermarket cats other than weight. As I recall past discussion on the cats, the OEM were warranted to 60,000 miles by the EPA laws with free replacement. The PCM has non-programmable firmware of exhaust flow/cats/content/etc required by the EPA for cars in the US. Professional tuners and a few individuals can reprogram around it but I am not sure if they can eliminate the code--they can make it non-reporting.
This week coming I will let you know. I am putting on Speed Engineering headers and a custom built x pipe with Flowmaster high flow cats. Having it all done Tuesday.
