Different type tire question...
Old May 13, 2012 | 10:32 PM
CharlestonTiger38's Avatar
CharlestonTiger38
Default Different type tire question...
Or I think it is...
If I run 245s up front and 305s in the back, would it give me problems?
It's still going to be 17" in front and 18" in back...
I don't have AH... just TC...
Old May 14, 2012 | 02:51 PM
CharlestonTiger38
Nobody?
Old May 14, 2012 | 03:18 PM
ALLEGRO's Avatar
ALLEGRO
You would need to run the 305's in 30 aspect to remain close to your desired stagger of diameter.
Old May 14, 2012 | 04:24 PM
Dope's Avatar
Dope
Resident moron
How about the full spec on the tires? 245/?/17 and 305/?/18
Furthermore, what exactly are you concerned about with the sizes?
Dope
Old May 14, 2012 | 05:21 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
use this link to plug in your tire/wheel combinatios to determine overall diameter and the rake.
http://rimsntires.com/specs.jsp
Old May 14, 2012 | 05:47 PM
CharlestonTiger38
Dope
I want the fronts to remain stock at 245 45 17. I want to change the back from 275 40 18 to 305 30 18. Basically, the only thing im doing different is adding a 10.5 wheel in the back.
I dont think will cause any issues at all. But, most of you might be able to enlighten me if there would be a problem with it...
Old May 14, 2012 | 05:49 PM
CharlestonTiger38
That's what I was thinking... thank you!
To Different type tire question...
