[Z06] Techron caused a gas guage problem?
Old May 18, 2012 | 10:19 PM
Seraphus's Avatar
Seraphus
Default Techron caused a gas guage problem?
Hey guys,
So a few weeks back I used techron in my 2002 Z06 (23k miles) for the first time. A day after I used it the gas guage started going all wonky on me. Up until this point I never had an issue with my gas guage.
I figured it'll clear itself up eventually but today the guage went flat and won't go back up anymore. So my questions are:
1) What the hell is going on?
2) I've heard of people resetting it and having the guage go back up, how do I do this?
Thanks for the help guys!
Old May 18, 2012 | 10:56 PM
MacCorvette's Avatar
MacCorvette
6th Gear
http://www.z06vette.com/forums/f4/er...reading-12131/
May or may not apply. Repost from the forum. As NCOA member I've switched to all AMSOIL products & became a dealer. Products are superior. My opinion.
Old May 19, 2012 | 03:13 PM
Seraphus's Avatar
Seraphus
I had read about the PCM reflash and may have to take it in and pay for it, but before I do that I'd wanna look at all my other options. For instance, everyone keeps saying that when they reset their PCM the guage goes back up, I'd like to know how this is done.
I'm also curious to see if this may have been caused by techron (since it happened a day after I put it in) or if running some mroe techron will help.
Old May 19, 2012 | 03:46 PM
ZeeOSix's Avatar
ZeeOSix
Do a search for "reading DIC trouble codes" ... also tells how to clear them.
Highly doubt it was the Techron. Did you over medicate it, or use the recommended amount?
Old May 19, 2012 | 04:16 PM
Seraphus's Avatar
Seraphus
Is it the same as just going into manual diagnostics and holding reset? If so, I've done that and it hasn't gotten right of the "check guages" warning and my needle is still down.
I waited for the tank to be empty and filled 3/4 of a 20oz bottle, then filled the tank full.
Old May 19, 2012 | 04:58 PM
ZeeOSix's Avatar
ZeeOSix
You have to hold the reset button while viewing the trouble code you want to clear on the DIC.
Old May 19, 2012 | 05:25 PM
Seraphus's Avatar
Seraphus
Yea I did that and have no codes now, but the warning is still there and the needle is still down to empty.
Old May 19, 2012 | 10:10 PM
ZeeOSix's Avatar
ZeeOSix
So if you check for trouble codes again, there are none showing up?
Old May 19, 2012 | 10:13 PM
Seraphus's Avatar
Seraphus
That's right. No codes.
Old May 19, 2012 | 10:21 PM
ZeeOSix's Avatar
ZeeOSix
The "Check Gauges" light is different than the "Check Engine" light. Since there are no trouble codes, then apparently there is something wrong with the gauge/sending unit that does not set a trouble code. But the "Check Gauges" light is on because the gas gauge needle is on "E" or dead for some reason.
From the Owner's Manual:
Check Gages Warning Light This light will come on briefly when you are
starting the engine. If the light comes on and stays on while you are driving, check your gages to see if they are in the warning areas.
This light can come on for the following reasons:
  • Low Oil Pressure
  • High Coolant Temperature
  • High or Low Battery Voltage
  • Low Fuel Level
Old May 20, 2012 | 02:28 AM
Seraphus's Avatar
Seraphus
  • Low Oil Pressure
  • Low Fuel Level
Yea that's the case here.
It seems like I have a few options form my research:
- Run some more techron and hope it clears up sulfur deposits
- Unplug and re-plug the fuel sender wires under teh car
- replace the sending units
So now I have one question; Can anyone show me a picture and point out which wires those are exactly?
Thanks for the help so far!
Old May 21, 2012 | 08:01 PM
TEXHAWK0's Avatar
TEXHAWK0
If you have not used Techron before, it could take more than one tank of gas to clean the fuel sender..
I would just run several tanks of fuel through it before I did anything else.
It still seems unlikely that the Techron would cause the sender to stop working...
Remember there are two tanks, so if you pour the Techron in a partially filled system, it may not mix evenly.
Old Jan 10, 2013 | 11:41 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
I just now came across your post...
As you can see here...not any sulfer buildup on these cards...
To Techron caused a gas guage problem?
