HELP - Temperature Display Lighting Problem
Old May 20, 2012 | 01:27 PM
Dragon Daddy's Avatar
Dragon Daddy
Default HELP - Temperature Display Lighting Problem
The display for my temperature control has faded and cannot be read.
I tried adjusting the lighting level; however, this did not address the issue.
Any ideas concerning a solution?
Thanks.
Old May 20, 2012 | 01:36 PM
jcgunn's Avatar
jcgunn
This is a well known and easily fixed (if you can solder) problem. Search the forum for "Dim HVAC fix" for the DIY.
Cheers
Old May 20, 2012 | 01:40 PM
dlind4's Avatar
dlind4
Go to C5 tech and at the top there is a DIY sticky for the HVAC dim display fix post 20 I believe. I just fixed mine friday and it did the trick I had numerous resistors loose on the board.
Old May 20, 2012 | 01:49 PM
Dragon Daddy
Cheers
Thanks!
Dragon Daddy
Thanks!
Old May 20, 2012 | 03:17 PM
Dragon Daddy
Cheers
Just fixed the problem.
Great solution.
Thanks.
Old May 20, 2012 | 03:18 PM
Dragon Daddy
Great solution.
Thanks.
To HELP - Temperature Display Lighting Problem
