[Z06] Clutch Replacement PLUS...
I have done quite a bit of research, and have put together a shopping list for the clutch replacement, and the "other stuff that you just do while you are there..."
There is NO way I will be ripping the rear end off my car again in 6 months to replace a guibo!!
The list comes to slightly under $8k
, so I wanted to get some advice before going further.So here is the list:
Clutch Replacement plus "while I'm there" stuff TOTAL: $7,893.67
Clutch Replacement Subtotal: $2,280.97
LS9X Clutch Kit Katech $1,899.00
Master Cylinder Kit Tick Performance $304.99
Speed Bleed Kit Tick Performance $49.99
ARP Pro Series Flywheel Bolt Kit Tick Performance $26.99
Pilot Bearing 14061685 $11.79
Torque Tube Re-build Subtotal: $1,428.34
3-1/4' Heavy Duty Carbon Fiber Driveshaft Driveshaft Shop $1,299.99
This CF driveshaft deletes the guibos (saving $400...)
Option 2: 2 x 19207077 (LS9 Guibos) $ 380 - $900 saving…
Torque Tube Bearing - Front 9107PP 1 off $40.23
Torque Tube Bearing - Rear 9108PP 2 off $88.12
Transmission Re-build Subtotal: $2,300.00
Strip, clean and re-build transmission
Re-ratio 5th gear to 0.84:1 to 0.80:1
Re-ratio 6th gear to 0.57:1 to 0.63:1 (Combined with diff re-ratio = ~5900RPM at 180MPH)
Estimate Mal Woods $2,300.00
Differential Re-build & Re-ratio to 3.73:1
Differential Parts Subtotal: $1,884.36 Carrier & Pinion Parts
Left axle shaft - C6 Z06 (2006-2008) 89060119 $47.51
Right axle shaft - C6 Z06 (2006-2008) 89060120 $31.61
Left side gear - C6 Z06 (2006-2008) 19180962 $62.90
Right side gear - C6 Z06 (2006-2008) 19181864 $105.29
Snap ring - C6 Z06 (2006-2008) 12458084 2 off $9.02
Clutch packs - C6 Z06 (2006-2008) 19132906 2 off $182.70
HD spring for clutches - C6 Z06 (2006-2008) 19132817 2 off $12.56
Option 2: 19132922 - C6 Z06 (2006-2008) Carrier complete - $695.51 (+ $60 assuming bearings included)
Pinion carrier assembly - C6 Z06 (2006-2008) 19133221 $131.69
Motive - Gears 3.73:1 (41-11) $399.95
Motive - Bearing Kit $220.00
Parts to Re-Seal
Axle seals 88996703 2 off $31.42
Side cover 'O' rings 89047953 2 off $38.22
Rear cover 'O' ring 89047954 $6.53
Trans/diff seal 'O' ring 12369456 $8.63
Output shaft seal (inner) 19206242 $8.37
Output shaft seal (outer) 12455045 $15.47
Miscellaneous
Pinion retaining nut 19133223 $11.93
Diff stud 88984492 $5.29
Shim Measuring Kit/Tools (off Ebay - hopefully) $400.00
Shims Subtotal: $155.27
Carrier shims
1.00mm 0.0393 in 89060047 1 off $8.28
1.25mm 0.0492 in 89060046 4 off $21.72
1.30mm 0.0511 in 89060045 3 off $24.72
1.40mm 0.0551 in 89060044 3 off $24.72
1.50mm 0.0590 in 89060043 1 off $8.40
1.80mm 0.0708 in 89060040 1 off $8.22
1.90mm 0.0748 in 89060039 1 off $8.40
2.00mm 0.0787 in 89060038 2 off $11.24
2.10mm 0.0826 in 89060037 1 off $5.46
Pinion shims
0.50mm 0.0197 in 88984481 1 off $5.62
0.30mm 0.0118 in 88984482 2 off $11.23
0.25mm 0.0099 in 88984483 1 off $5.75
0.20mm 0.0079 in 88984484 2 off $11.51
I am planning to do most of the work myself (including the diff re-build), but will be getting the transmission done by a local pro (he used to do all of the Aussie V8 Supercars).
I know I am buying a lot of diff shims, but because I'm in Australia, I don't want to wait 3 weeks, 'cos I don't have the right one! Also the reason I am not buying a pre-built diff. Freight from Australia back to the US is more than the core charge!
Thoughts? Advice?
I like the fact that there are only a handful of C5's in the country, and even less Z06's!
I've spent another $12k on my Z since I bought it, mostly on the usual stuff;
Vararam, Kooks headers & hi flow cats, 'Big 3' axle back, 36 lb/hr injectors, 160* thermostat, MSD plug wires, Motorsport wheels (+1") with Toyo R888s, a HID headlamp conversion and of course a copy of HP Tuners...
I'll probably have to split the job in two to get it past the finance committee, otherwise known as my better half...
My only concern with that, is doing a big takeoff with my new clutch and driveshaft, and spitting the rear end all over the road.
The goal here is to bullet proof the drive train, so I can look a bit deeper under the hood and find some more hp.
I want to add an ECS trans/rear end brace later, as I don't need to strip half the car out to install it. (and probably a tunnel plate at the same time).
I'd love to do it now, but it's another $400.
What sort of power level do the trans/rear end braces become essential?
