X pipe w/delete cats..codes
Old May 25, 2012 | 10:18 AM
Torch Vette's Avatar
Torch Vette
Default X pipe w/delete cats..codes
IF I INSTALL AN X PIPE WITH THE CAT DELETE USING THE EXISTING SENSORS/LOCATIONS WILL I HAVE ANY CODES SHOW AND HAVE TO BE PROGRAMMED OUT..?? 2001 COUPE W/Ti's...stock headers..
ANY HELP/ADVISE WOULD BE APPRECIATED..RickA
Old May 26, 2012 | 01:03 AM
Raj0235's Avatar
Raj0235
Yes you will. The computer will think the car is running too rich and will throw codes. You will either have to get them tuned out or you will need to buy o2 sensor spacers either options will help. I ran into this problem when i did mine. Napa should have the parts if you wanted to go that route.
