My 203 50th. anniversary coupe came with door rests. But they look hideous. How do I go about removing them without damaging the door panel ? I got some 50lbs fishing line and I thought if I left it out in the sun this weekend, and see if I can cut them off with the fishing line or is there a better way ? I got a real nice embroider set from CorvetteAmerica and I added some more 3M automotive double-face tape. But I really need to remove them without damaging the door panel. Please help !
That's about the only way I know how to get them off.
OK, if thats the normal way out in the sun to get them off. Any suggestions as to how I clean the door panel plastic and not ruin it? I want to install the two custom ones later once the door panels clean. Thank you !
Hey man, what custom arm rests are you talking about? Where did you buy them? I've never seen anything advertised except the stock ones that are add-on's. Let me know what you're going to put on. Thanks!
