[Z06] Clutch Engagement Question
My car has 25k miles, it does not get driven real hard, but there is something i wanted to know.
Does clutch wear and tear directly correlate to where the clutch engages?
As far as i can tell, my clutch works great, fluid is clear, but if you thought about clutch engagement as a value between 1 and 10, with 1 being at the floor, and 10 being all the way up, i would say mine regularly engages around 7.
Is there an adjustment, or is my clutch literally worn most of the way down?
Now quit thinking & go out & drive it.
If you don't drive your car hard, I doubt if you will ever have a sticky clutch pedal or missed gears.
Good luck.
Good luck.
I do not understand exactly what you mean by the automatic adjusters built in, are you saying that they adjust the engagement no matter the amount of wear?
In other words, a brand new clutch, and a completely worn out one will engage around the same place?
Measurements were made with a ruler from the floor to the top of the pedal.
Results:
Pedal all the way up = 8.0"
Pedal all the way down = 2.5"
Clutch just starting to engage = 4.5"
Clutch full engaged = 6.75 ~ 7.0"
So you can see the clutch engagement range is when the pedal is 4.5" to 7.0" off the floor. When the pedal is anywhere between that range, then the clutch is in some state of partial engagement.
