A/C Pressure Readings
Wanted to get some feedback on my 2000's A/C pressure readings. I used to have a chart but cannot locate it. Just wanted to make sure my pressure readings are in the "safe level."
Ambient Air Temp: 77 degrees
Humidity %: 45% (estimate)
Static Low/High PSI: 68 (engine off, both gauges match)
Low Side PSI: 28 (engine at idle, max A/C)
High Side PSI: 215 (engine at idle, max A/C)
The vents are blowing very cold (40-42) but the static PSI of 68 seemed high to me. Perhaps it's right where it needs to be, however.
Thanks.
