Shifter shaft
Old May 31, 2012 | 12:56 AM
chasboy's Avatar
chasboy
Oldtimer
Default Shifter shaft
Anyone cut their shifter shaft to shorten it??
Old Jun 5, 2012 | 07:31 AM
chasboy's Avatar
chasboy
Oldtimer
ttt
Old Jun 5, 2012 | 10:03 AM
I have seen some posts here on the forum where the owner did cut the shifter shaft to accommodate a different shift **** or to just have a shorter shifter. Here's some links:
http://forums.corvetteforum.com/c5-g...+stock+shifter
http://[http://forums.corvetteforum....+stock+shifter
There may be more threads out there too. Just used the search function and typed in cutting stock shifter.
Old Jun 5, 2012 | 10:48 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I have not cut mine but did get a Hurst Style round shift **** which threaded farther down on the shifter shaft which IMO made a big difference. Maybe give this a try. Good luck.
Old Jun 5, 2012 | 11:33 AM
jake2000's Avatar
jake2000
I was getting ready to buy a C6 shifter but I'm gonna try this first. You gotta love this forum!
Old Jun 5, 2012 | 01:06 PM
chasboy's Avatar
chasboy
Oldtimer
I've been making custom shift ***** for my car for a few months now. With the wood *****, I can basically bury the shaft, forcing the boot way down. Works great for bar type *****, but I recently found a source for delrin and other types of ***** that I can make into *****. I'm limited to depth by the diameter of the ****. I really like the white delrin **** I have on there now, but I would love to lower it so it can hit the boot, since the piping is nearly the same color.
I just don't want to screw up anything.
Jack, thanks for the research, I'm going to those links now.
Old Jun 5, 2012 | 01:15 PM
chasboy's Avatar
chasboy
Oldtimer
Thanks again Jack. Wish I thought of that terminology when I searched. Think I'll tackle that now.
Old Jun 5, 2012 | 01:19 PM
No problem. The forum has a vast wealth of info just sitting out there.
Old Jun 5, 2012 | 08:49 PM
chasboy's Avatar
chasboy
Oldtimer
Well guys, I cut a tad over 3/4" off, and here is the result. It's a little stiffer going into reverse but otherwise no significant effort adjustment, and it DOES shift 'shorter'. I like the change a lot.
Old Jun 6, 2012 | 12:55 AM
ALLEGRO's Avatar
ALLEGRO
Cut a full inch off mine, right down to the minimum number of threades necessary to re-install. I really like the outcome.
Old Jun 6, 2012 | 01:27 AM
striper's Avatar
striper
I cut mine down and threaded it down as far as it can go. I like the difference it made.
To Shifter shaft
