Copy an past the direct link from the pic you would like to post. In photobucket if you hover over the pic a drop down box will appear an choose direct link.
I posted up some of your pictures for you, but seeing that you have them in Photobucket already, all you need to do is right click the IMG tag under the pictures. When place your mouse on the picture in Photobucket, a drop down menu will appear. at the bottom of the menu you will see IMG code. Click the code inside the box. Next you simple past that into you post you have on the forum. You will find it best to have the browser opened twice, one with the forum and one with Photobucket. That way you can simply go back and forth.
