DIY TMPS change?
Old Jun 3, 2012 | 03:28 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Default DIY TMPS change?
How difficult would it be to change a TMPS without going to a tire shop?
Anyone done this?
Old Jun 3, 2012 | 04:36 PM
memmer's Avatar
memmer
Do you mean TPMS
Old Jun 3, 2012 | 05:55 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Originally Posted by memmer
Do you mean TPMS
Yes, had a senior keyboard moment.
Old Jun 3, 2012 | 08:08 PM
toddk's Avatar
toddk
This seems like an odd thing to try and save money on, unless you have the equivalent tools to dislodge and remount the tire. If you have runflats, the sidewalls are even stiffer than normal tires. I've struggled just changing a mower tire with prybars and screwdrivers, so wouldn't ever consider it on my C5. First, I don't want to mark or damage my rims. Second, I would want a rebalance afterward which I can't do either.
I swapped all 4 older pre-'01 TPMS to newer 01+ for $40 total at Discount Tire (I brought the new ones in, and kept/sold the old ones). I originally had the tires installed there, and they had free lifetime balancing. Might not hurt to call around to see what the going rate is for just one.
Todd
Old Jun 3, 2012 | 08:32 PM
dougbfresh's Avatar
dougbfresh
How do you plan this mis-adventure? Ever try to breakdown a runflat???
Old Jun 3, 2012 | 08:39 PM
3318C5's Avatar
3318C5
I would have to agree here. Some things are better left to professionals! Changing the TPMS is not the issue. Getting the tire off is. If you had a tire machine, you would have to remove the tire (run flat if you have stayed stock). I have seen pro's fight to get run flats off! Then do the TPMS work. The re-mount & probably balance the wheel........
Old Jun 3, 2012 | 08:54 PM
jrose7004's Avatar
jrose7004
Without a tire machine to dis mount and mount tires, I'd say it would be next to impossible to do yourself.
Old Jun 3, 2012 | 09:38 PM
OkieBikerDude's Avatar
OkieBikerDude
I don't understand why it is necessary to remove the tire from the wheel. Granted, breaking the bead isn't all that easy but that can be done with little danger to the wheel. Once the outside bead is down you should be able to reach the TPMS with one hand while removing the nut with the other.
What am I missing?
OBD
Old Jun 3, 2012 | 09:57 PM
Certainly not worth the possibility of damaging the wheel in the process.
Old Jun 4, 2012 | 06:32 AM
dougbfresh's Avatar
dougbfresh
What am I missing?
OBD
Try it at home some time and get back to us.
Old Jun 4, 2012 | 09:33 AM
fendermender's Avatar
fendermender
What am I missing?
OBD
Well you are half correct. They can be changed by only breaking the bead loose on one side of the tire. This also eliminates the need for rebalance as the tire won't move in relation to the rim. But... I can't imagine getting the bead loose without a proper machine.
Old Jun 4, 2012 | 11:11 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
My tires are non-run flat Hankooks. Am not that cheap, just looking into doing the work my self.
Old Jun 4, 2012 | 08:09 PM
92GA's Avatar
92GA
Oldtimer
What am I missing?
OBD
Well after I rebuilt my sensors, I took my tires to DT to have my new Hankooks installed. I had one sensor that wouldn't read the air pressure so I had to replace it. Didn't want to drive all the way to DT again so I went down to a local tire shop close by. I had them just break down the outside so I wouldn't need a rebalance. Let me tell ya it's a heck of a job to try and pry the tire down enough to replace the sensor. Those sidewalls are really stiff, scratched the heck out of my hands. Won't do it again.
Old Jun 4, 2012 | 08:16 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Not worth the trouble.
I helped my older brother change tires at home once a long, long time ago.
We broke the sidewalls loose by putting a jack on the sidewall and jacking up another car to get break them down. Then it went to crowbars and large screw drivers....
Old Jun 4, 2012 | 09:05 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I have changed a few tires at home too. It is not easy. Breaking the beads is really tough. The ones I did were 60 and 70 series so the sidewalls were taller and more flexible.
I have used a tire machine to change tires also. C5 wheels and tires are still tough. The shorter sidewalls and especially run flats the sidewall is very stiff. Even with the bead broken the tire is wide enough that it stays close to the bead. It is tough to push down far enough to change a valve stem/sensor.
I wouldn't even think about doing it without a tire machine.
Old Jun 4, 2012 | 09:18 PM
OkieBikerDude
This answers my question. I thought I made myself clear that I might be missing some of the facts. I have also used a bumper jack base to "break down" a sidewall and over the years learned that the base of a small hydraulic jack works equally well and is a lot more manageable. I wasn't sure the low profile sidewall would limit access to the sensor.
Thanks for the info.
OBD
Old Jun 4, 2012 | 09:21 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It can be done, All you need to do is break the bead at the sensor, But it is a lot easyier said than done, It is only a few bucks to have a shop do it and that is what I would do.
To DIY TMPS change?
