Lowering ?
Old Jun 4, 2012 | 09:35 PM
theheartbeat's Avatar
theheartbeat
Default Lowering ?
Hi guys just droped it down on stock bolts. my ? Is for those of you that have no bolts up front. How do you take them off is thier any other parts needed. And how low is you ft with no bolts? Also where can i find the c6 bolts for the rear. Pics please. Thanks guys
Nick
Old Jun 4, 2012 | 10:52 PM
theheartbeat
Old Jun 5, 2012 | 12:05 AM
theheartbeat
BueLer........
Old Jun 5, 2012 | 08:23 PM
tsbbzm's Avatar
tsbbzm
Originally Posted by theheartbeat
BueLer........
Old Jun 5, 2012 | 11:43 PM
yaknow's Avatar
yaknow
I removed the stock front bolts by, removing the (2) lower shock bolts and upper (4) A arm bolts, jacked up the spring and removed. I replaced my fronts with C6 lowering bolts and lowered the rear to the max with exixiting bolts. If not satisfied with the rear get some longer grade 8 bolts and nylock nuts for the rear
Old Jun 6, 2012 | 08:48 AM
theheartbeat
Sounds good. Woud you have a write up on this? I just ordered the front lowering bolts from WCC.
thanks.
To Lowering ?
