How to correct RDCM and LDCM codes
Old Jun 7, 2012 | 08:46 PM
ToplessBlonde's Avatar
ToplessBlonde
Default How to correct RDCM and LDCM codes
Hi everyone!
I have been having issues with my 98 Vert not starting so I followed the advice in another thread and pulled the codes from the DIC. One set of codes that came up for both Doors ( LDCM and RDCM) was Battery 1 and 2 fault. What does this mean and how do I correct them?
Old Jun 7, 2012 | 09:27 PM
kris6868's Avatar
kris6868
I had the same problem a few years ago an I took the Vette into a local Vette shop an the told me they went thru an clean the electrical connections and harnesses. Never had a problem since. Hopefully it may work for you too. I wanna say I was charged 75 bucks for it.
Old Jun 8, 2012 | 08:46 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. Battery needs to be looked at in the engine bay or the connections from it to fuse box right there. The codes you saw for the door control modules simply say the main battery for the car is low.
Old Jun 8, 2012 | 12:09 PM
ToplessBlonde
Thanks, I appreciate your imput. I replaced the battery about 6 months ago with a brand new Die Hard, so I am surprised that you are mentioning it could be a battery problem. Now, I thought that if a code had an "H" it was a history code. I've cleared all the codes and attempted to restart the car. It threw the P1631 H C code only.
Ok...here is a list of all the codes I received prior to clearing them
P1571 H - ASR Desired Torque
P1631 H C Theft Deterrent Password Incorrect
TCS
C1277 H - Requested Torque Signal CKT malfunction
BCM
B2721 H - Pass Key Detection Circuit
IPC - none
HVAC
B0363 H
B0367 H - Right and left actuator feedback open
LDCM
B2282 H - Battery #1 Fault
B2284 H - Battery #2 Fault
B2262 H - Horizontal Position Sensor Fit
RDCM
B2283 H - Battery #1 Fault
B2285 H - Battery #2 Fault
I really appreciate your help. I'm worried I am going to go somewhere and not be able to start the car at all. Let alone the fact that it is throwing codes at all...
Old Jun 8, 2012 | 01:46 PM
dgrant3830's Avatar
dgrant3830
Clear the codes and see what comes back. Be sure to check the battery cables at the starter solenoid as well since this is where the alternator ties into the battery. Do not forget that its electrically hot there.
Old Jun 8, 2012 | 08:56 PM
RedSoxFan's Avatar
RedSoxFan
Excuse me while I hijack this thread for a minute. 8VETTE7, you provide some of the most useful information on this forum. There are others (Dee Gee and Bill Curlee come to mind and I tip my hat to them as well). It seems that whenever someone is having serious problems you respond with very knowledgeable and helpful responses. I just wanted to say thank you.
Originally Posted by 8VETTE7
Causes of the no start.
Key pellet is not being read correctly. Try another key or clean the pellet on the current key with the eraser on a pencil and then wipe clean and/or use an aerosol contact cleaner in the ignition cylinder to clean the fine wire that reads the pellet on the key. Spray into the cylinder and then insert and remove the key 10 or 12 times wiping the key clean with a lint free cloth between insertions. Repeat if needed.
The P1521 and C1277 have nothing to do with the nostart. They could be the result of a bad battery or ground problems or a bad EBCM. Could even be from a ignition switch (different from the ignition cylinder) that needs service.
Here is some info on diagnosing removing and repairing the ignition cylinder:
diagnosis
http://forums.corvetteforum.com/1568186703-post64.html
removal
http://forums.corvetteforum.com/1571067145-post107.html
repair procedure
http://forums.corvetteforum.com/c5-t...ch-repair.html
Old Jun 8, 2012 | 09:17 PM
Xx_Black-out's Avatar
Xx_Black-out
St. Jude Donor '08-'11-'12
diagnosis
removal
repair procedure
Originally Posted by ToplessBlonde
Hi everyone!
As others stated, don't fret over the LDCM/RDCM faults. You can simply replace/jump start your battery and those faults will show up in your history. Looks like 8VETTE7 gave you the info you're looking for
To How to correct RDCM and LDCM codes
