[Z06] Tire Wear Question
Old Jun 8, 2012 | 11:48 AM
LIGHTNING's Avatar
LIGHTNING
Default Tire Wear Question
Outside treads of front tires feel rough to the touch...inside treads feel smooth.
Looks to me like they're wearing evenly. 17k miles on them. Not sure if you can tell from pic's (outside treads are right side of pic's). Any thoughts??
Old Jun 8, 2012 | 08:47 PM
Xx_Black-out's Avatar
Xx_Black-out
St. Jude Donor '08-'11-'12
You probably need a slight alignment...
Reference:
http://www.procarcare.com/includes/c...dtirewear.html
Old Jun 8, 2012 | 09:53 PM
LIGHTNING's Avatar
LIGHTNING
Reference:
Good info...thanks!
Old Jun 9, 2012 | 12:37 PM
gotz06?'s Avatar
gotz06?
Reference:
Old Jun 9, 2012 | 05:37 PM
SuzukiDan7's Avatar
SuzukiDan7
Alignment, or maybe you are taking some hard corners ?
Old Jun 9, 2012 | 08:47 PM
LIGHTNING's Avatar
LIGHTNING
Uh..what would make you think that?!
I've heard that alignment settings on the ZO6 are set with negative camber...designed for hard cornering...& if you do most of your driving on highway you'll actually wear insides of treads.
Old Jun 9, 2012 | 09:12 PM
ZeeOSix's Avatar
ZeeOSix
I think the photos look pretty good. I've see way worse uneven wear than that.
Old Jun 9, 2012 | 10:28 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Both of my 02Z's have worn the tires much worse than this. I had the alignment fixed to prevent this on the next set on my first Z. My second Z is now ready for front tires and will be aligned soon after the new tires are installed.
To Tire Wear Question
