DIC codes - help please...
Old Jun 10, 2012 | 10:28 PM
tracks03's Avatar
tracks03
Default DIC codes - help please...
Hey, guys, I've got some dreaded DIC codes that I can't figure out:
28-TCS C1214H
60-IPC B0516H
Please advise of the meaning, what to expect, and what to do!
Old Jun 10, 2012 | 10:44 PM
joestrazz's Avatar
joestrazz
Try here, you should put it in you favorites;
http://www.stengel.net/diccodes.htm
Old Jun 10, 2012 | 10:48 PM
joestrazz's Avatar
joestrazz
The first one is a Sol valve relay contact and the secound is speedometer signal. Both are historic because of the H, if they are active you sould get a C.
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
How do you put threads in a list of favorites? I can't find it!
DSTURBD
Old Jun 10, 2012 | 10:50 PM
joestrazz's Avatar
joestrazz
I meant to go to that webpage and put that page in the favorites so you can get to it later.
Old Jun 12, 2012 | 12:05 PM
tracks03's Avatar
tracks03
Thanks for the link. I was trying to find out more about what it would take to fix the problems.
so, with the relay, odds are I'll have to pull the ECBM and at least check the soldering? or go ahead and replace the relay to be sure?
and the speedometer: i recently went from the std OEM wheels and tires to C6 OEM sizes. Could that be what set the code off? Should i reprogram for the new tires?
Old Jun 12, 2012 | 01:22 PM
joestrazz's Avatar
joestrazz
I don't think you have to do anything since they are both historic "H" codes and not current "C" which means that these alarms were valid at one time but not now but I would like to hear from someone with a little more knowledge than me verify my answer.
Old Jun 12, 2012 | 08:36 PM
tracks03's Avatar
tracks03
I'll keep a lookout for more trouble. I was getting a "Service Traction Control" message sometimes too, but not every time I drove the car.
To DIC codes - help please...
