Colder thermostat
With a 160*F stat, my oil temps are over 200*F, so much for the myth that the condensation won't by drawn off by the pcv.
But verify that your a/c condensor & radiator are clean as mentioned.
Russ Kemp
Russ Kemp
Pops
Fluid is being exchanged - Open is Open - Anything over the TStat temp
is radiator to block - block to radiator... does not matter what temp it opened at if the temp is over the opening ...
Peace
Chip[/QUOTE
all you guys that think lowering the thermo temp will allow the car to run colder, think about this : if the thermo controls operating temp, then REMOVING the thermo ( the same thing as installing a " 0 degree" thermo ) should make the car run at ambient temp.IT WON'T !!Lowering the thermo temp ONLY establishes when the thermo opens, not the engines operating temp.
there's a whole lot of other things that effect the engine's operating temp.
It might help if you think of a thermo as a switch - once it reaches its op temp, its on. Its passive not active.Expecting it to "control" the op temp is like expecting a standard light switch to deterrmine the brightnees of the light bulb it controls.
To the op, leave tour thermo alone.
Keep in mind: I live in southern California with summer now here, and I have modifications to my car and a dyno tune that has the tuner suggesting a cooler thermo. I think it is the thing to do.
Also, taking the thermo completely out is not a good idea at all and is not a substitute for a lower opening temp thermo.
On these modern engines it is only safe with a sophisticated retune for that particular thermostat. There are so many factors at work here that one shouldn't go to the lower t-stat & accompanying tune unless there is complete confidence in the tuner.
If the resulting tune and new t-stat yields lower operating temps than original engineering design for complex engines like the LS series, one should definitely be on the safe side and change oil NLT every 3,000 miles.
Oil contaminants burn off properly at certain designed temp bands and even a perfect tune for the lower t-stat will not overcome that simple fact.
I'm not sure after reading your comments that you do. If you want your temps lower, swapping your stat out won't do it, adjusting the "on" temp of your fans will, but not address the cause of why they are getting high to start with. Others have given you good advice, but it seems you are sold on changing yours out. It's a 15 minute job if nothing goes wrong.
I'm not sure after reading your comments that you do. If you want your temps lower, swapping your stat out won't do it, adjusting the "on" temp of your fans will, but not address the cause of why they are getting high to start with. Others have given you good advice, but it seems you are sold on changing yours out. It's a 15 minute job if nothing goes wrong. On these modern engines it is only safe with a sophisticated retune for that particular thermostat. There are so many factors at work here that one shouldn't go to the lower t-stat & accompanying tune unless there is complete confidence in the tuner.
