Help, Where does this blue connection connect?
Old Jun 15, 2012 | 03:52 PM
kris6868's Avatar
kris6868
Default Help, Where does this blue connection connect?
I just removed my windshield washer tank an this blue connection was underneath it. Where does it go?
Its insane i just happen to find it.
The last pic is there the wire comes off of...
I have no idea
Old Jun 15, 2012 | 03:58 PM
jfernandez98's Avatar
jfernandez98
I believe it is for sensor on bottom of tank.
Old Jun 15, 2012 | 04:04 PM
86 vetter's Avatar
86 vetter
I agree, it would be the float sensor which tells you when the tank is empty.
Old Jun 15, 2012 | 04:11 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
When the washer fluid gets low you will get a warning on the DIC. They have been known to send the message even when they are not low, so maybe the previous owner disconnected it, or had the tank out and forgot to plug it back in.
Old Jul 21, 2012 | 10:06 AM
VetteBoy1979's Avatar
VetteBoy1979
CI 3-4-8 Veteran
St. Jude Donor '07-'09-'12
I just found this plug myself in attempting to get my windshield washers to work again. I plugged it in, turned on the car, and the washer pump runs non-stop without even turning on the wipers.
Did some research and found this is most likely a switch that has gone south or the wiper stalk. I just unplugged it and will just forget about it, if I can.
To Help, Where does this blue connection connect?
