[Z06] K&N Filter
Old Jun 15, 2012 | 08:01 PM
fnunez's Avatar
fnunez
Default K&N Filter
I just purchased a 2008 Z06, 6700 miles. I am interested in replacing the air filter element with a K&N kit #63-3060. I am told and have researched it enough that it is worth the money as it delivers HP to the rear wheels. My question is: Would I have to re-calibrate (reprogram) the ECU due to the severe change of air coming in freely as opposed to stock unit sucking air through a straw? And also, I have been warned that the oils used on the K&N filters (orange in color) may get sucked up through the intake and land on the MAS (Air Flow Sensor) and create a problem? If anyone can help me with this I would appreciate it. Thank you. FNunez.
Old Jun 15, 2012 | 09:14 PM
pluslt's Avatar
pluslt
I don't think a filter change is going to require a program. Maybe if you were doing some other things too. Re: the oil on the maf. Just don't over oil it and you'll be fine.
Old Jun 15, 2012 | 09:23 PM
fnunez's Avatar
fnunez
Thanks for the input, I didnt think that it would require a reprogram but better safe than sorry, I just thought some one in here has done the K&N box and may have pros and cons. Again, thanks. FNunez
Old Jun 16, 2012 | 01:04 AM
pcbunn's Avatar
pcbunn
I've been running the K&N filter in my '01Z without any issues. Didn't need to reprogram the ECU and just use the minimum amount of oil.
Old Jun 16, 2012 | 02:49 AM
hxrly's Avatar
hxrly
I bought my Z06 with one of those two-cone filters and kept triggering lean codes at low speed. Got rid of it and installed the stock airbox with a new k&n filter; no more codes and the car runs strong.
To K&N Filter
