I got my c6 zo6 repos put on yesterday. With new BFG 295/35/18 tires on the back and since the front tires were in good shape i got them put on the new sets of wheels 275/40/17. One of my tpms were bad on the front right and it had been that way since i bought the car so when i got the new wheels I just didnt put the front sensors on the wheels. Now when I crank my car it says "Front left tire flat" "Maxim speed 55 mph" "reduced handling" If i drove over 60 it is really hard to control and it feels like the rear end keeps swaying back and forth and I dont have much control over the car. Is not putting tps on the front causing this or is it something to do with not having the right size tire on the front?
My "guess" is that it's the size of the tire.
My tire pressure sensors in my 02 haven't worked in a long time and I've never seen that message.
Good choice of the rear tires, I recently purchased those exact same tires for my 98.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have never seen reduced speed with a bad sensor, You might check the plug that goes to each hub and make sure they have a good conection, Having a bad sensor will not cause the issue you have, You might also try to see if you are getting any codes, If your car is going into reduced speed I would think you will have a code.
Mr.Bill
Originally Posted by 8VETTE7
Apparently neither of you have read the owners manual. The message received is because the TPMS thinks the tire is FLAT. It DEFINITELY is related to TPMS.
If you don't have an owners manual you can download a free one at
I have never had a flat, I have ran my car with a bad sensor before with no issues, I didn't know the car would go into reduced power mode because of a flat, New to me. Thanks for your knowledge, I now now more than I thought I did.
Mr.Bill
The size of the tire has nothing to do with the pressure in the tire. The computer is looking for a pressure signal; That's all. There are no sensors that check for tire height. People put different size rims and tires on all the time. If you have no sensors up front, the computer doesn't think there is any pressure in the tires. I would put some sensors in. They obviously were working somewhat if you had them and no trouble messages, and got rid of them and now have trouble messages.
You are way off here, Each hub has a sensor which does check the speed of the tires front and rear, If your tires are not 1/2 inch or a bit more between the front and rear your car will go into reduced power mode, AH/TC will not get a good speed reading if the tires are not in spec. Also he may have 2 issues here, The tire size and the TPMS. Just a thought.
Is that on later models? I only have an ABS wire leading to my fronts. Where is the other sensor? I apologize if I am wrong. I've just never heard of that.
Like I said in post #2, I haven't had working TPMS in my 02 for many years and I've never seen the message the OP has.
I do not know that as a fact but I have heard (or read) that before.
Once again you hop on the band wagon with no information or any experience or anything helpful to say.
You have no idea what your talking about. Just agreeing because you are upset at me from another thread and looking to lash out at me. Grow up bud. Have a nice day
When I rebuilt my sensors and had my new tires put on, one didn't read pressure and my car went into reduced power also. If the computer thinks you have a flat it will try and keep your speed below 55 mph.
You're right, the experience Mr. Bill described and I agreed with wasn't mine, but my Discount Tire guy shared pretty much the same story about his C5.
As to being upset and lashing out.....? Over something said on an internet forum? Wow...
Well from the feedback I've gotten I'm guessing the tires and the sensors are both causing the problem. So could anyone tell me the right size tire I should be running in the front? And where to get a sensor besides the dealership and know which one is the right one to get.
