Horn relay
Old Jun 17, 2012 | 07:46 PM
no01k's Avatar
no01k
Default Horn relay
What is the easiest way to remove the horn relay? Really fits tight.
Old Jun 17, 2012 | 10:06 PM
onebadeagle's Avatar
onebadeagle
Default Relay
Just pull straight up, maybe wiggle it a little
Old Jun 18, 2012 | 01:00 PM
bighank's Avatar
bighank
Default It IS TIGHT
Old Jun 18, 2012 | 06:53 PM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We have them in stock if your in need of one.
Old Jun 24, 2012 | 09:59 PM
no01k's Avatar
no01k
Fixed horn problem...switched horn and fog relays ....both work
Old Jun 25, 2012 | 12:19 AM
Vettelover1990's Avatar
Vettelover1990
Was the problem you were referring to the horn just beeping without you hitting the steering wheel? if so please pm me.
Old Jun 25, 2012 | 06:46 AM
fhd's Avatar
fhd
4th Gear
Hi
I'm having the same problem as you said can you pleas help me with it?
I pulled the horn fuse to stop it no horn now
2002 coupe 6spd
Old Jun 25, 2012 | 08:23 AM
GEMcLean's Avatar
GEMcLean
Sounds to me like the horn membrane in steering wheel.
Here is link to video on replacement.
http://corvettepartscenter.com/online-shop/c5-1997-2004
Common problem. I just replaced mine.
Part is abou $60. Takes about an hour to replace.
Old Jun 25, 2012 | 12:32 PM
no01k's Avatar
no01k
Horn would not work ..
To Horn relay
