Another Plasti-Dip Question
Old Jun 21, 2012 | 02:46 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Another Plasti-Dip Question
I posted a few weeks ago about plasti-dipping my C6 Z05 wheels and doing a red stripe on the lip to tie it in with the Torch Red exterior.
Now that I am also 100% sure that I am going to do it, I started to think about first the center cap and the lug nut covers. First on the center cap I ordered them plain when I ordered the wheels as I did not want the C6 logo on the caps and I added the C5 logo decal. I wondering if I should leave that small area chrome, not the whole cap, just the small area that has the logo. Secondly, will the paint stick to the plastic lug nut caps and when I put them on I normally use a 3/4 inch socket and small extension, but I worry that this will remove the plasti-dip.
Any suggestions on these issue?
Old Jun 21, 2012 | 03:55 PM
johnsos30's Avatar
johnsos30
Plasti-dip the lug nuts then install them. If any dip comes off after they are tightened down, spray a little dip on them again.
Old Jun 21, 2012 | 04:05 PM
robert21122's Avatar
robert21122
i lefted mine chrome looks good
Old Jun 21, 2012 | 04:15 PM
SoDiezl350's Avatar
SoDiezl350
I've read of lug nuts coming loose because of being plasti-dipped. I would just buy black lug nuts to be safe.
Old Jun 21, 2012 | 10:16 PM
And as for the center cap, might look OK with just the logo left chrome. If once you do it it doesn't look quite right, you an always redo it easily enough.
Old Jun 21, 2012 | 10:20 PM
Breze84's Avatar
Breze84
Yea, its called Matte Clear Coat and be easy when you remove or tighten them
Old Jun 21, 2012 | 11:51 PM
thechosenone's Avatar
thechosenone
I got some black lugs nuts (20) not painted but bought that way ill sell you for $20.00, used once.
To Another Plasti-Dip Question
