How often do you need to change differential oil?
Old Jun 27, 2012 | 05:44 PM
01vetter's Avatar
01vetter
Default How often do you need to change differential oil?
My manual doesn't say anything about changing it. My vette is an 01 with about 42k miles. A year ago I did the MN6 transmission.
Old Jun 27, 2012 | 06:02 PM
Cirrus8's Avatar
Cirrus8
Change it now. If you do not, you may start hearing strange noises from the back of your vette. It will sound like it is a bad bearing especially in a tight turn. That noise is the limited slip clutches in need of LIMITED SLIP FLUID. I changed mine and replaced the diff lubricant with Mobile 1 lub that has the limited slip fluid already mixed in.
Old Jun 27, 2012 | 07:50 PM
jerrys vette's Avatar
jerrys vette
i've got 19 k miles on mine. rear sounds like bad bearing, but i thought it
was the run flat tires/ tread pattern. now i am curious. need more input.
Old Jun 27, 2012 | 08:18 PM
bearphoto's Avatar
bearphoto
SoCal Events Coordinator
St. Jude Donor '12
Doesnt your manual have a service recommendation or schedule in the back? change it now, its inexpensive
Old Jun 27, 2012 | 08:28 PM
2002BlackMN6's Avatar
2002BlackMN6
The new GM fluid # 88862624 already has the LSD additive in, I just did mine last month.
Old Jun 27, 2012 | 08:47 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
Same here. GM dealer had the fluid in stock - 2 qts - about $35 IIRC.
Old Jun 28, 2012 | 06:40 AM
Won't hurt to change it now - easy to do and not very expensive.
Old Jun 29, 2012 | 05:21 PM
Steve Goetsch's Avatar
Steve Goetsch
Where is the differential drain plug on a 96? Also is it better to use lube with posi additive in it , or buy a synthetic gear lube and use the GM posi additive.
Old Jun 29, 2012 | 05:56 PM
ALLEGRO's Avatar
ALLEGRO
Mobil 1 LS
Old Jun 29, 2012 | 09:23 PM
01vetter's Avatar
01vetter
Default Manual doesn't mention changing differential oil
I couldn't find any mention of changing oil. I only saw checking the level. That's the reason for this post.
Old Jun 30, 2012 | 01:40 AM
ALLEGRO's Avatar
ALLEGRO
I would just change it and be done with it. The type of driving dictates much of the "necessary" maintenance required that has no "real" mention in the service manual.
Good luck
Old Jun 30, 2012 | 08:10 AM
torchredmadness's Avatar
torchredmadness
I changed all the fluids when I bought our car. It had 32,000 miles on it. I probably didn't need to just did it anyway.
Old Jun 30, 2012 | 08:15 AM
MGP1's Avatar
MGP1
2020 C6 of the Year Finalist - Modified
Pay a little now or alot later...Preventative maintenance is key.
Old Jun 30, 2012 | 09:01 AM
Jedi926's Avatar
Jedi926
Old Jun 30, 2012 | 02:56 PM
Steve Goetsch
I want to change the differential oil on my 96 but cant find the drain plug, anyone know if their is one, if so, where. Thanks.
Old Jun 30, 2012 | 04:07 PM
LoneStarFRC's Avatar
LoneStarFRC
I would say check your OM or post up over on the C4 boards for help.
Old Jun 30, 2012 | 04:21 PM
LoneStarFRC
Originally Posted by ALLEGRO
Mobil 1 LS
More choices:
To How often do you need to change differential oil?
Old Jul 1, 2012 | 10:25 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
20 to 25k is the conventional wisdom
Then stick one of these in it
http://www.customcorvetteaccessories...inplugkit.html
Peace
Chip
__________________
..................Click for
Old Jul 1, 2012 | 10:46 AM
C66 Racing's Avatar
C66 Racing
I changed the diff fluid in my 02 Z06 at something like 800 miles and now change it about every 8 track days or so. But, mine has been mostly a track car from the start. In what was my daily driver from 06-09, a 2006 CTS-V which essentially a C6 drivetrain (LS2 engine), I changed the diff fluid at 10k miles:
2006 Cadillac CTS-V Used Oil Analysis Factory Fill Differential Fluid
The lab's suggestion was to change the fluid (which I had already done).
I currently use:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
This fluid has friciton modifier already in it and extra is not needed for the C5/C5 Z06.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 1, 2012 | 10:54 AM
KillSwitchNY's Avatar
KillSwitchNY
[/QUOTE]AMSOIL Severe Gear Extreme Pressure Synthetic 75w90[/url] (Product Code SVGQT)
This fluid has friciton modifier already in it and extra is not needed for the C5/C5 Z06. [/QUOTE]
****, I just changed my gear oil yesterday with the Amsoil. I knew it had the modifier in it already but i put a 1/2 bottle of the GM additive just in case so the clutches wouldn't chatter. I guess I'll have to romp on it and make sure im still using both tires.
