10.5's all around?
Old Jul 3, 2012 | 12:23 AM
chassed's Avatar
chassed
Default 10.5's all around?
Is it possible to run repo C6 Z06 10.5's all around?
I searched but it just mentioned OEM wheels...
Old Jul 3, 2012 | 12:34 AM
ALLEGRO's Avatar
ALLEGRO
A couple of things here.
First, I am not sure that the 10.5 is going to fit up front and allow full-lock turning.
Second is that regardless, you will still need to maintain the 0.5 to 1.5 inch difference between front and rear tire sizes to keep your AH/TC happy.
Keep us posted.
Old Jul 3, 2012 | 08:15 AM
PushinTheLimit's Avatar
PushinTheLimit
Lots of racers use the 18x10.5 OEM C5 rear wheels as a square setup. But we also run with traction control/active handling off so that's not an issue. It will fit in the front, but at full lock, you will rub your lower control arms slightly.
Old Jul 3, 2012 | 10:55 AM
chassed's Avatar
chassed
I won't be auto crossing, just daily driving.
Thanks for the help guys!
Old Jul 3, 2012 | 02:20 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
You'll turn full lock a LOT more daily driving than any sort of racing. Just parking alone.
Unless there is a real need, I wouldn't go 10.5 on the front. I went 9.5 on the front and the steering effort is noticeably different.
Old Jul 3, 2012 | 02:38 PM
chassed's Avatar
chassed
Right, but the OEM 10.5's are 58mm offset.. And that fits up front... The repos are 56mm offset. I'll be running a narrow tire as well, to boot.
Old Jul 3, 2012 | 03:05 PM
youngrigo's Avatar
youngrigo
Alot of people that auto x or road course their car use the 10.5 stock wheels in the front as well.
But if your going to be daily driving it i wouldn't recommend it as it is also going to following the lines of the road more with the wider tires
Old Jul 3, 2012 | 10:44 PM
LedfootLarry's Avatar
LedfootLarry
I Run 19 X 10.5 all around 62mm offset , 305/30/19 r, 285/30/19 f, rubs front a arm slightly at full lock, you will be fine.
To 10.5's all around?
