Drive versus Overdrive?
Old Jul 5, 2012 | 03:56 PM
PIN DR's Avatar
PIN DR
Default Drive versus Overdrive?
I have a 2004 coupe with the auto transmission. I'm looking for some input from the group on the use of Drive versus Overdrive.
In drive at roughly 60mph I am running about 2,000 rpm. If I put it in overdrive it drops to about 1,500 and the result is that when slow pulling up hills it will make the dreaded "drone" louder. Other than decreasing gas milage a little, is there any harm in using drive all the time and running a bit higher rpm at regular highway speeds? I would always use overdrive on the interstate since I run 70+ there, but for county roads and highways is 2,000 rpm, or perhaps a bit more, for long periods harmless?
Jeff
Old Jul 5, 2012 | 04:08 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
It is perfectly fine. When I had an A4 I would sometimes use drive when on country twisty roads.
I don't know what the manual says about it, as I have never had an A4 C5, but any manual I ever read stated use D when at slow speeds and/or your tranny starts to shift back and forth from D to OD.
OD was created simply to increase fuel mileage due to cafe standards. The bonus was less stress and wear and tear on the engine as a result while at high speeds.
My C4 would run 2K at 70 while in OD, so drive away my friend. It's actually better on your tranny to not have it shifting back and forth.
Old Jul 5, 2012 | 04:27 PM
killain's Avatar
killain
Oldtimer
Default 4L60 in drive ?
My 2003 just states you can stay in third if the roads are hilly or operating in rural twisty, but I never really give it much thought as it's pretty flat around here, I just put in OD or fourth gear. But if I lived at the other side of my state or North of here up in the Blue Mountains, it would be slightly more expensive, but it would be easier on the engine to run in 3 gear. I don't know about your exhaust system, I have a Corsa 'Pace Car' system and I never have any drone in any gear, and it is pretty quiet up around 60-70MPH.
Old Jul 5, 2012 | 05:22 PM
ALLEGRO's Avatar
ALLEGRO
Its all about fuel economy
Old Jul 5, 2012 | 06:34 PM
It won't hurt anything to do what you describe. I always keep mine in OD, but that's just my preference.
Old Jul 5, 2012 | 07:32 PM
jrose7004's Avatar
jrose7004
Boom!
Old Jul 5, 2012 | 07:33 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Hell I keep it in 2 while in the neighborhood just to hear the GHL's sing
Old Jul 6, 2012 | 10:32 AM
PIN DR's Avatar
PIN DR
Thanks guys, that's what I figured. It's got to be better to have the tranny not going back and forth between overdrive and drive all the time. Heck, if i put a lower gear in the car, it would run about 2K in overdrive at 55 anyway! That is what my C-4 did.
Exhaust system is a Borla catback. I LOVE the way it sounds outside the car, but at 1500 RPM it's got some serious drone. Fortunately, at interstate speeds I run closer to 1,800 in overdrive and that is nice and quiet.
Jeff
Old Jul 6, 2012 | 10:41 AM
Vettmann17's Avatar
Vettmann17
When in traffic or when on roads where I don't go over 40 I usually keep it in 3. Car slows better with less braking and I feel better in control at slower speeds. All other times I just keep it in OD.
To Drive versus Overdrive?
